Old 03-12-2015, 12:32 PM   #1
Amount of fluids - motor oil, water, atf, mtf, coolant, hydraulic, brake…
Please check your service manual. All fluid amounts are noted in there!
This is for the 2.7 and 3.2 litre engine.
Engine oil change without filter: approx. 8 litre
Engine oil change with filter: approx. 8.25 litre
Coolant fluid Boxster: MT approx. 18 litre,
Coolant fluid Boxster: AT approx. 19 litre
Coolant fluid Boxster S: MT approx. 22 litre
Coolant fluid Boxster S: AT approx. 23 litre
Transmission MT Boxster: approx 2.25 litre
Transmission MT Boxster S: approx 2.6 litre
Transmission Tiptronic S: approx 9.8 litre
Differential Tiptronic S approx. 0.8 litre
Hydraulic steering: approx 1 litre
Brake fluid: approx 0.4 litre
Window washing system without Litronic: approx. 2.5 litre
Window washing system with Litronic: approx. 7 litre
Please always measure the amount of fluid you drain and fill in the same amount as a starting point.
Regards from germany
Markus
Old 03-12-2015, 01:15 PM   #2
Thanks a bunch!! This will be really very helpful as reference. Much appreciated.
2001 Seal Gray Boxster (Hair Salon on wheels)
2013 Audi Q5 (Family Mover)
2006 Yamaha R1 (Adrenaline Machine)
amitmishra4 is offline   Reply With Quote
