Old 03-12-2015, 10:26 AM   #1
mountainman's Avatar
tiptronic trans like new
changed the filter and fluid in the tiptronic in the 04 Boxster S LE yesterday. The fluid was not burnt, but was very black with a good bit of sludge in the bottom of the pan. No metal at all. Was able to drain out about 4 liters of fluid and replace it.
I have had no problems of not with the transmission (73K miles) but have noticed that it downshifted a bit hard and not as smoothly as before. I guess you get used to gradual change and do not notice it too much or maybe you just expect things to wear and function differently, but when I took it out for a test drive I could not believe how smoothly it shifts and feels. Like a new transmission. Based on the difference I had, I can't believe Porsche waits til 90K to service the transmission.
One of the best $150 I ever spent. Now the C 4 needs it.
Old 03-12-2015, 10:36 AM   #2
The Porsche tiptronic is am adapted MB NAG 1 722.6. Until 2005 Mercedes Benz recommended to do ATF oil and filter changes first at 90 K miles. And than no more. They've called it a lifetime fill.
In 2006 they had enough experience with bad transmissions of MB cab drivers. They've changed the ATF and ATF oil filter interval to 60.000 Km. And no longer a lifetime filling.
60.000 Km is 37.5 K miles.
Hope that helps.
Smallblock454 is online now   Reply With Quote
Old 03-12-2015, 11:26 AM   #3
Luv2Box's Avatar
90K miles is too long for these Tips. Mine started acting up at 74K and I had it serviced and it shifted like new. 60K is the longest I'll go again without servicing it.
Luv2Box is offline   Reply With Quote
Old 03-12-2015, 12:53 PM   #4
woodsman's Avatar
wait a minute- we're not used to easy fixes around here...
Old 03-12-2015, 01:47 PM   #5
my next change will be about 30K more miles since it was so dirty and I was only able to drain about half. Then I will see how it looks and judge future changes.
Old 03-17-2015, 11:43 AM   #6
Xpit77's Avatar
I had mine done while getting the new LN IMS installed.
99 Boxster sold
88 944S sold
Xpit Formula Four sold
95 Integra Solo I sold
71 Opel GT sold
