Old 03-11-2015, 07:57 PM   #1
DavidsBoxster's Avatar
Need Help
My coolant tank apparently has a leak since I have a puddle under my trunk carpet. My question is, has anyone purchased the tanks I see for $68 at carparts.com and are they any good? Where would you recommend buying the part from? I already replaced the cap since it had the old style but the dealer here in Indy charges $50 for the cap so don't want to buy tank from them since they are SO overpriced.
DavidsBoxster is offline   Reply With Quote
Old 03-11-2015, 08:27 PM   #2
I purchased the OEM part so can't help you on the one you mentioned. All I can say is it's a kind of 'no fun' DYI. I wouldn't want to have to do it again.
Old 03-13-2015, 05:11 AM   #3
DrCactus's Avatar
I bought mine off of EBAY which was a couple hundred if I recall - coming out of China or something like that. It fit perfectly and had it in my car now for 3 years and no issues at all. That leak is a common thing that most cars go through I found - Porsche should have made it a recall as the crack seems to happen in the exact same spot for everyone. Good luck.
DrCactus
Old 03-13-2015, 05:24 AM   #4
I am my own mechanic....
Timco's Avatar
Hmmmm. Sounds like another part that tends to fail, only this one blows up the engine. I'd rather see a recall on the IMS.
'08 VW Touareg T-3 wife's car
Tags
coolant leak , coolant tank
