Old 02-09-2015, 09:55 AM   #1
Flasher Module location/replacement?
Hi,
Can someone confirm the exact location of the flasher module on a '98 Boxster? Also, do they just pull out/push in?
Thank You,
2002 Boxster S
1998 Boxster Tip
2004 Cayenne Turbo
Taipanic is offline   Reply With Quote
Old 02-09-2015, 02:36 PM   #2
1999 base
Meir's Avatar
Originally Posted by Taipanic View Post
Hi,
Thank You,
the relay is located in the relay box above the fuse panel (on the driver side kick panel).
and it will pull out and push in just like any relay.
relay No. 3 , marked in red
Old 02-11-2015, 07:11 AM   #3
Thank You, that is where I thought it was, once I realized it wasn't in the frunk.
Do they just pull out? I had tried to pull it out but it seems pretty tight in there, I didn't want to break anything without confirming.
Thanks!
2002 Boxster S
1998 Boxster Tip
2004 Cayenne Turbo
Old 02-11-2015, 07:30 AM   #4
On the slippery slope
JayG's Avatar
Thanks!
they are tight. Just pull. If you wiggle it as you pull it is easier
2004 996 Targa Tip
Instructor - San Diego region
Old 02-13-2015, 12:59 PM   #5
Cool, Thanks! Figured so but just wanted to make sure before breaking something.
2002 Boxster S
1998 Boxster Tip
2004 Cayenne Turbo
