Old 02-07-2015, 11:55 AM   #1
jpc763's Avatar
Brake Wear light came on today
Got the car washed today and after the brake wear light came on. I dropped it at the shop and they will let me know on Tuesday. My wife thinks it was the car wash. Is that possible?
2001 Boxster S - Midnight Blue Metalic
jpc763 is offline   Reply With Quote
Old 02-07-2015, 12:30 PM   #2
What does a visual inspection tell you about the brake pads themselves? Sometimes all four brake pads don't wear evenly. It could also be faulty sensors.
2001 Seal Gray Boxster (Hair Salon on wheels)
2013 Audi Q5 (Family Mover)
2006 Yamaha R1 (Adrenaline Machine)
amitmishra4 is offline   Reply With Quote
Old 02-07-2015, 01:29 PM   #3
jpc763's Avatar
Well I dropped it at the shop so I can't check.
Old 02-07-2015, 06:14 PM   #4
rdass623's Avatar
time to replace the brake pads. normal maintenance. I highly recommend using ceramic pads, less dust to clean off of your wheels. when the light is illuminated you still have a few thousand miles left, so you would have time to order your pads online if you choose to do so.
2005 Porsche Boxster S, 2000 Porsche Boxster 2.7L Base, 2000 Mazda Miata LS Supercharged, 2010 Toyota Tacoma TRD Off Road
Previous Vehicles: 2005 Ford Mustang GT, 1986 Alfa Romeo Spider, 1971 Alfa Romeo GTV, 1999 Ford Mustang
1977 Toyota Celica GT
rdass623 is offline   Reply With Quote
Old 02-07-2015, 06:27 PM   #5
If the light comes on, do you need to buy new sensors?
DG Boxster is offline   Reply With Quote
Old 02-07-2015, 06:38 PM   #6
Reebuck1
wear
Yes some times water can cause the light to come on if the sensor is slightly nicked.
Reebuck1 is offline   Reply With Quote
Old 02-07-2015, 08:00 PM   #7
The brake sensor works by looping wire around the end of the sensor. When the rotor wears through the wire and breaks the circuit, the Brake Service light on the dash turns on. Its that simple.
So yes, usually if the light turns on, you will have to replace the sensor that indicated the fault.
Old 02-08-2015, 06:40 AM   #8
thom4782's Avatar
This happened to me. Light went out after the brakes dried out. Nevertheless, it was time to replace the pads and (for me) the rotors too.
