Old 02-07-2015, 06:06 PM   #1
Push-on electrical terminals for brake switch and bridge plug
I'm doing a cruise control install on my 98 Boxster. I have to add a wire to the existing brake control switch and a few wires to the bridge plugs behind the fuse panel.
I thought I could use standard 1/4" push on terminals. At the brake switch at least, the standard terminals I have fit on the switch contact fine but don't fit in the connector housing.
I think the bridge plugs may be the same thing.
Does anyone know where to get these little terminals? I can't seem to find a reference here, or on Pelican. I don't want the whole connector, just the terminal that goes on each wire. I imagine they are crimp terminals.
Thanks for any info!
DG Boxster is offline   Reply With Quote
