Old 01-10-2015, 09:01 PM   #1
HereIam's Avatar
AARG! How do you remove the windscreen??
It seems like it should be easy enough...the tabs are designed to lift up. That's what the manual says, and that's what forum folks say. But I swear, if I pull up any harder, they're sure to snap right off. What gives?
FYI, one detail I noticed in the manual. It appears a top portion of the clips pops up to make way for the upward motion of the lever. Not happening for me, though...is this the problem? I did try carefully prying on it with a screwdriver to make it pop up, but it didn't want to budge, and I didn't want to break it.
HereIam is offline   Reply With Quote
Old 01-10-2015, 09:26 PM   #2
Multi-Boxer Driver
Deserion's Avatar
Push the tabs towards the middle of the car. The windscreen pushes backwards.
(I had to go check to make sure I wasn't imagining. )
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
Old 01-10-2015, 10:42 PM   #3
Fintro11's Avatar
just reach back to grab your coat from behind the windstop, it should pop right out as your hand hits it :P at least that's what happened to me, was able to pop it back in with no damage to the clips at all haha
Old 01-12-2015, 12:18 AM   #4
HereIam's Avatar
Tried again, and a piece snapped off. I'll let the dealer mess with it, and try not to be ashamed I can't figure out a stupid clip.
Old 01-12-2015, 07:41 AM   #5
Porsche9's Avatar
Pelican parts has the replacement clips that you now need.
03 Carrera
89 Carrera 4
89 944 S2
78 911SC
Old 01-12-2015, 04:10 PM   #6
Box4two's Avatar
Even though the clips look like they are meant to move toward the center, they actually move towards the rear, I snapped both of mine, bought new ones at the P dealer for about $5 each.
Previous 2 seaters:
1975 Triumph TR7
1979 Fiat X19
1977 Lotus Esprit
Honey it's an investment!
Box4two is offline   Reply With Quote
Old 11-12-2016, 09:13 AM   #7
POG champ, 1995.
Bumping this old thread.
I recently broke both of mine (Boxster noob), new clips on the way from Deutschland.
How did you replace them?
1999 Boxster 2.5l 5-spd. 168k miles and climbing.
Build: http://986forum.com/forums/show-tell-gallery/63257-greta-not-really-build-so-much-maintenance-record-build-thread-w-bs.html
IG: @ryanjboutin
ryanjboutin is offline   Reply With Quote
Old 12-03-2016, 08:37 PM   #8
POG champ, 1995.
On the underside there is a small cutout (shown in above picture), stick a small flat head screw driver in there, and the broken tabs just popped right out.
New tabs in place.
Took a bit of finagling to get them in there (without breaking) but they're in.
IG: @ryanjboutin
