Old 01-04-2015, 12:51 PM   #1
Dead Battery '00, what electrical connection to use?
I have a buddy with an '00 Boxster S, he has a dead battery and unfortunately he does not have the red pull out section inside his fuse box to hook a jumpbox to. Anyone know exactly how to (short of pulling fender well, tires are too close) hook up a jump box to get enough juice to pop the hood?
Old 01-04-2015, 01:20 PM   #2
Here's a picture of his fuse block:
Old 01-04-2015, 01:43 PM   #3
Alternatively, I suppose he could use one of those cigarette lighter charger adapters, a company called Deltran makes a product called "Battery Tender" and makes a cigarette socket adapter for it that you can just plug into the wall at the other end. I think if he leaves it plugged overnight, he should have enough juice to pop the frunk, maybe even enough for a start.
2001 Seal Gray Boxster (Hair Salon on wheels)
2013 Audi Q5 (Family Mover)
2006 Yamaha R1 (Adrenaline Machine)
amitmishra4 is offline   Reply With Quote
Old 01-04-2015, 02:08 PM   #4
Thanks amitmishra4. I spoke to him on the phone and he employed a jump-pack with a male to male lighter connection. Unfortunately he was limited on time and had to return the borrowed Jump-Pack. Will try it later with more juice for a longer period hopefully. There is no power source where the car is being stored.
Old 01-04-2015, 06:55 PM   #5
Guess I'm confused...my 2000S just has a cable actuated lever for the trunk and frunk....Power is not an issue.
Old 01-04-2015, 07:12 PM   #6
My cable levers have gotten "stuck" in the lock position with dead batt. Not sure if it's normal.
OP: your friend needs to apply 12V+ to both sides of fuse C3 and 12V- to a good ground (door catch). With power connected, close the doors, then lock and unlock the car using the key (not the fob). The levers should now be unlocked
I've heard that a simple 9V battery will do it, but I've never tried.
