Old 11-24-2014, 08:28 PM   #1
kjc2050's Avatar
Originally Posted by brjak View Post
I have a 97. Do i have the same options available to me? Do not want to get caught without access to battery.
Yes. ,,,,,,,,,,,,,,,,,,,,,
Old 11-24-2014, 08:59 PM   #2
jaykay's Avatar
Mike Focke' s pages had a link to a set of instructions IIRC. I made my own release years ago....by sliding the manual release to a more secret convenient location
986 00S
Old 11-25-2014, 10:41 AM   #3
Box4two's Avatar
I removed the plastic trim in the frunk where the latch is, and as I was going to remove the headlight, I saw the cable, managed to fish it out and relocate it to the tow hole.
Previous 2 seaters:
1975 Triumph TR7
1979 Fiat X19
1977 Lotus Esprit
Honey it's an investment!
Box4two is offline   Reply With Quote
Old 11-25-2014, 04:50 PM   #4
Nice! So you found another way to get the cable without having to remove the headlight or the pazsenger tire. Good work. Is it easier to fish the cable to tbe tow hook cover from the latch?
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 11-25-2014, 05:42 PM   #5
Perfectlap's Avatar
I have one of these. it fits in the rear shelf. Didn't have to jump start the car but it gave the car enough juice to open the frunk so I could replace the battery.
https://www.youtube.com/watch?v=xUNpTUMbuSM
I also have this Cobra jumpack. Haven't figured out if it will power up from inside the car yet though.
https://www.youtube.com/watch?v=obseEGdlb2g
BORN: March 2000 - FINLAND
Old 11-25-2014, 06:12 PM   #6
Box4two's Avatar
I still routed it down behind the bumper to the tow hook and made sure it has an unobstructed route
Previous 2 seaters:
1975 Triumph TR7
1979 Fiat X19
1977 Lotus Esprit
Old 11-25-2014, 01:13 PM   #7
Mine has a lever beside the drivers seat. Does seem like any power is used when opening the fruck, or trunk. Does any one know if the lever works without power?
1997 Boxster! (Tiptronic)
brjak is offline   Reply With Quote
Old 11-25-2014, 01:27 PM   #8
jaykay's Avatar
I am pretty sure you have cable operated releases. Nevertheless they do get locked up by a local solenoid once the battery dies.
986 00S
Old 11-27-2014, 03:51 PM   #9
So if the battery dies, and it locks by local solenoid. Whats the use of running an emergency cable for when the battery dies. Seems the cable would be useless if it locks by local solenoid.
Old 11-27-2014, 07:25 PM   #10
jaykay's Avatar
The levers that pull the release cables are prevented from moving, however you can still pull the release cable via other means if you can get to it. There is a emergency cable that is looped around the main release cable; pulling it will unlock your frunk latch.
IIRC this cable is stuffed under the right front fender liner...( please verify as I changed this many years back) and hard to get to. Many have rerouted such that it can be used when needed.
986 00S
Old 11-25-2014, 02:47 PM   #11
You have a 97, went to electronic release in later years.
