Old 11-19-2014, 09:17 PM   #1
golonaus's Avatar
auto trans replacement
hi
im about to purchase small project
2000 S with bad transmission
I will probably use audi/vw box
what's my best bet?
will trans from lets say 2002 audi s4 have more aggressive gearing than from a4?
do I need to change computer too , or the one in the boxster will work?
thx in advance
ps.
yes, i did search
just want to be sure before Ill pay the guy
99' with 3.4l engine. ROW tune. SAI delete
Old 11-20-2014, 05:34 AM   #2
Multi-Boxer Driver
Deserion's Avatar
Not sure the S4 trans will work since it's set up for AWD (rear output shaft). Gear ratios should be posted online somewhere for comparison to the stock Porsche gearing. Perhaps an A4/Passat (B5 chassis) would be a comparable fit (if parts are changed, such as the axle flanges).
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
Old 11-20-2014, 06:04 AM   #3
JayG's Avatar
Why don't you want to go with the proper Porsche transmission?
Old 11-20-2014, 11:13 AM   #4
golonaus's Avatar
audi/vw boxes are the same but without P tax
you can get one for 3-400$ compare to porsche 1500-2000$
there is little difference in gearing tho
Old 11-20-2014, 02:22 PM   #5
78F350's Avatar
ZF 5HP19 FL applications from the parts catalog:
Looking further in the catalog, it looks like the gear ratio is the same for all of them (Top of page 6). True? I don't know.
Old 11-20-2014, 02:46 PM   #6
JayG's Avatar
Based on that, VW and Audi share some transmissions, which is not surprising at all, but Porsche is different
if you go through the catalog, you will see that there are different housings and torque converters as well
