Old 11-08-2014, 07:45 PM   #1
More's Avatar
Squeeky Mattress
My 98 is starting to sound like an old squeeky mattress on every turn and bump. A mate suggested I oil it but which part that is the question?
Cheers!!
1998 Porsche Boxster 986 Convertible.
More is offline   Reply With Quote
Old 11-08-2014, 11:28 PM   #2
Steve Tinker's Avatar
Use the search function - its been discussed many times....
There are many control arm bushes & ball joints, coffin arm bushes & ball joints, drop links, shock upper bearing mounts (if its noisy when turning), anti roll bar rubber bushes, etc. etc. but its the ball joints & anti roll bar bushes that usually squeak
There are rubber gaiters (boot) over the suspension ball joints that dry out - you will need to get the car on jackstands & remove the wheels to get to them. The trick is to inject Lithium grease into the rubber boot - some people cut the boot & squirt WD40 in, but its better to prise the top of the boot open with a small pick and inject the Lithium grease. Anti roll bar rubbers need to be removed to lubricate.
This is a temporary fix, though some people have had some success for a couple of years.
2001 MV Agusta F4.
