Old 10-31-2014, 11:07 AM   #1
986 puzzle
aiite guys... taking bets ... or guesses .... what leaves:
- 2 small drops of oil ...
- 1 in front of the other spread about 2 inches apart.
- on the right side of the engine
- in front of the rear wheel, approx where the vent is at
fyi
RMS & IMS changed 10,000km ago
AOS changed about 5000km ago
BTfd2e93 is offline   Reply With Quote
Old 10-31-2014, 11:33 AM   #2
Oil filler tube is cracked is my first guess. Typical problem.
Second guess is leaking valve cover gasket(s).
Old 10-31-2014, 11:34 AM   #3
jsceash's Avatar
I'm going to say it depends on the year. First guess is a leaking spark tube cylinder 2.
Old 10-31-2014, 11:36 AM   #4
jsceash's Avatar
Oil filter is on the left side.
Old 10-31-2014, 11:37 AM   #5
Sorry.. forgot to mention my car is a 2001 boxster base.
So far.. the guesses are encouraging!! Not too difficult or $$$ to fix.
Old 10-31-2014, 12:22 PM   #6
Variocam solenoid cover?
pharaohjb is offline   Reply With Quote
Old 10-31-2014, 05:33 PM   #7
Artist, 986S tinkerer
NewArt's Avatar
Um, he said oil filler tube
And it' not expensive but a bit of a pita to replace.
Old 10-31-2014, 06:15 PM   #8
jsceash's Avatar
OOPS! don't I feel stupid.
Old 11-10-2014, 08:21 PM   #9
follow up on this topic. ... havent had a chance to get it on jacks to check out ... but interesting i noticed that it only drips a small amount of oil after spirited driving. It would seem symptoms converging to the oil filler tube?
Old 11-11-2014, 07:14 AM   #10
Autobahn Glanz
WhipE350's Avatar
Most likely cause is oil filler. Such a PITA! I had my transmission out when I replace mine and had neck problems for a month after doing it! Get under the car, shine a flash light all the way up to where it connects, it will be obvious if it is dripping. there is a second place that tube also leaks and that is over the joint on top of the engine, but that tends to puddle where it lands and doesn't make it to the ground so easy.
Old 11-11-2014, 08:48 AM   #11
I had the same oil drops in the same place approx. 5-6 years ago. It turned out to be a leaking cam tower cover. The car was still under warranty, so the dealership fixed it. Otherwise, I've read where others have just tightened down the cover bolts.
Old 11-11-2014, 02:44 PM   #12
I am my own mechanic....
Timco's Avatar
This. Plug tube.
'08 VW Touareg T-3 wife's car
Old 11-12-2014, 08:55 PM   #13
Autobahn Glanz
WhipE350's Avatar
Yes good one, spark plug tubes do like to ooze oil. Bad enough it will drip.
