Old 10-27-2014, 04:20 PM   #21
BIGJake111's Avatar
Originally Posted by Einherjar View Post
Looks like possibly a cat...right one to be more specific. Have to throw it up on a lift to be sure.
If the cars cold hit the cat and see if it makes any noise.
Old 10-27-2014, 06:04 PM   #22
Ill try that tomorrow morning and let you know.
Einherjar is offline   Reply With Quote
Old 10-28-2014, 03:36 PM   #23
Definitely an exhaust related issue...tapped around on the exhaust pipes with engine running and could induce the rattle or make it stop.
Old 10-30-2014, 05:50 PM   #24
Found the culprit. Right side, heat shield near the Catalytic Converter...I think. The heat shield is no longer attached and just spins freely on the pipe.
Old 10-30-2014, 06:42 PM   #25
Pdwight's Avatar
Very good.....I have to check mine
So....how would you repair that ??
Old 10-30-2014, 09:12 PM   #26
2002 Boxster S
I would try a bead of JB Weld epoxy.
2009 Carrera S cabrio
silver-S is offline   Reply With Quote
Old 10-30-2014, 09:28 PM   #27
nieuwhzn's Avatar
Have the same issue and have been whacking the heat shield for a couple years already.
Just drive the heat shield to the back of the car by hitting it with a mallet.
OR replace the secondary cats with test pipes.
nieuwhzn is offline   Reply With Quote
Old 10-31-2014, 07:45 PM   #28
gonna have a buddy of mine tac-weld it. Although I did not think of JB weld, may try that first.
