10-22-2014, 05:33 AM
#1
Beep on lock after overfilling gas?
Hi,
Yesterday I noticed when I pulled into the A&P parking lot that my alarm did a single beep on lock. I unlocked and locked again and heard a single beep.
5 mins before that, I had stopped at a gas station to get gas and the guy in an effort to round the $ off had over filled about 40 cents worth which caused the excess gas to overflow. I got out and noticed that there was an overflow hole there thankfully and most of the gas drained out onto the concrete below. I had him wipe off the gas he spilt on the paint and drove on.
5 mins before that, I had just put the top down since the sun was out and it was a pleasant day and the top was down the rest of the day.
I did not see any other problems with the car, drives fine and no errors/lights.
Could the top being down or the gas having overflowed caused the beep? Never heard it before. I have a wifi OBD2 reader courtesy of Timco here. Will that read alarm codes as well?
Thanks!
2001 Seal Gray Boxster (Hair Salon on wheels)
2013 Audi Q5 (Family Mover)
2006 Yamaha R1 (Adrenaline Machine)
10-22-2014, 05:49 AM
#2
Track rat
The beep is a warning that a hatch is open and the car is not secure. Top down or unlocked gas fill door can cause it.
10-22-2014, 05:56 AM
#3
I don't get a beep when my top is down when locking. For me it has always been the center console, if I get a beep I unlock the car, and then open and re-close the center console, and then it is good.
I'm not sure where the microswitch is for the gas cap but I guess if gas got sloshed on it it could have degraded and now failing to report that the tank is locked. Or some gas got on the servo or whatever it is that locks the gas tank when the car is lock.
As a test, you could try to open the gas cover after you have locked the car to see if it indeed did lock.
But the first test I would try is to check the doors, front and rear trunk, and especially the center console, to make sure they are securely latched.
Steve
#4
Make sure your center console lid is completely shut (press and listen for click) I'm sure you did, but also make sure your decklid/frunk are completely closed. Other than that, just the top being down shouldn't make it beep. Maybe make sure the top is completely down, or raise it and lower it again. I don't think it has anything to do with over filling gas, as I have overfilled mine many times.
10-22-2014, 06:02 AM
#5
Yes, I read about the center console on the forum and the trunk and frunk. Everything is closed.
The one suspicion I do have is that when you lock the car, the gas filler lid usually locks too. There is a little stalk that comes out and latches the fill door. In my case, that little stalk moves but has not locked since the day I bought the car. Since the stalk moved a little, it may have closed the micro-switch and caused the alarm system to believe it was closed. Maybe the overfill damaged that micro-switch, I will have to do some investigation to see if the latch is still moving and try a few things tonight.
10-22-2014, 07:08 AM
#6
Damn Yankee
What guy? Are you implying that there are still gas stations with attendants?  Or did this incident happen in 1960?
Just wonderin'.........
TO
10-22-2014, 07:57 AM
#7
Yeah, I live in NJ - its state law here. Even though, when I ride my motorcycle, I always end up pumping my own gas.
Timeline: A brief history of why you can't pump your own gas in New Jersey | NJ.com
Cant say it is not nice in the winters when its freezing outside and you dont have to get out. I tip them a buck and they clean the windscreen and pump my gas. I feel like i help preserve some jobs too
TO
10-22-2014, 08:00 AM
#8
On the slippery slope
TO
Oregon, no self service- state law
It is weird to have someone pump your gas. I remember as a kid , it was cool to pump the gas in to the car. not any more
2004 996 Targa Tip
Instructor - San Diego region
10-22-2014, 08:12 AM
#9
Luckyed
Same thing in the Garden State.
No self serve.
2001 Base 2.7 - Arctic Silver - 5 speed - Comfort Top -
3-4 Stalk OBC Upgrade - Double DIN Head Unit
10-22-2014, 12:50 PM
#10
Damn Yankee
I honestly did not know that there was a law in some states prohibiting self serve.
Can't remember the last time I saw an attendant at a gas station. I was a part-time pump jockey back in college, and that was in the early 70's.
I remember being out with my Dad, and him pulling his big sedan into Poust's Service Station. Two, sometimes three, uniformed attendants (with caps) swarmed over his car; filling his tank, checking his oil, water, and wiper fluid levels, and even his tire pressure. Two bucks gave us the service and 8 gallons of gas.
Just reminiscin'.......
TO
