Old 03-21-2006, 06:30 AM   #1
Cool How to remove the boxster lettering
I would like to remove Boxster lettering. How do you do it? Do you need a tool? I I do not want to leave scrape marks.
porscheracer is offline   Reply With Quote
Old 03-21-2006, 06:38 AM   #2
bmussatti
Posts: n/a
I have read posts that people remove the badge with dental floss and then clean-up the sticky residue with a little cleaner that won't harm the finish, and then complete the job with a good polish and waxing on the trunk lid.
I simply ordered my 987S from the factory without the badging...and Porsche is kind enough not to charge for that "option". Imagine that...from Porsche!!
Old 03-21-2006, 06:39 AM   #3
fab
fab's Avatar
I haven't done it. But I've read that some folks tried dental floss to remove it.
00 Boxster Tip Blk/Blk
100% de-ambered
painted center console
painted bumperettes
autoband paint protection
wheel caps & colored crests
door sills
Valentine One
fab is offline   Reply With Quote
Old 03-21-2006, 07:05 AM   #4
going to try it.
thanks for the reply...dental floos plus wd40 will work..
Old 03-21-2006, 07:11 AM   #5
bmussatti
Posts: n/a
porscheracer, go to the search function in the tool-bar and enter the word "floss". You will see some good postings about your question.
I have not seen the WD-40 recommendation, and would not use it...sounds too messy.
Old 03-21-2006, 08:18 AM   #6
I used 4-Star paint cleanser (which is supposed to work at removing bugs and grime from the front bumper, etc.) It worked great.
Phil Buxton is offline   Reply With Quote
Old 03-21-2006, 04:54 PM   #7
Use dental floss to break thru the glue, then clean off the residue with 3M adhesive remove and imperial hand glaze. I would not use wd40.
Chris C Atlanta is offline   Reply With Quote
