Old 10-20-2014, 04:31 PM   #1
mustang2porsche's Avatar
leaking coolant trying to find where
long story short, I'm leaking coolant in my 01 boxster S, looked underneath and it seems to be coming from under the engine so I took both engine covers off and it seems to form a puddle on the passenger side near some hoses and pullies. any ideas?
01 Boxster S BlacK/Black 6 speed (Totaled: Engine, Trans, and ECU Salvaged)
2001 boxster S Grey/Grey 6 Speed ( not stock and don't know whats been done to it)
Speed doesn't kill, It's the sudden stop that does.
mustang2porsche is offline   Reply With Quote
Old 10-20-2014, 04:36 PM   #2
A common cause for coolant leaks is the coolant tank. It is on the passenger side.
Old 10-20-2014, 04:42 PM   #3
still plays with cars...
BoxsterSteve's Avatar
If it's dripping from the water pump, you'll be able to tell... Usually dried crud or drops around the pulley shaft.
Six speed 2000 Boxster S
Old 10-20-2014, 04:46 PM   #4
jsceash's Avatar
If I'm hearing you correctly, you are seeing a water leak on the front right corner of the motor. If that is the case you probably have a bad water pump.
Old 10-20-2014, 04:46 PM   #5
I think the water pump is the lower left pulley ( if looking into the car) I can't see it, but can tell there's something dripping.... is it hard to change a water pump on these.
Old 10-20-2014, 04:50 PM   #6
jsceash's Avatar
That is the water pump pulley.
Old 10-20-2014, 04:50 PM   #7
Coaster's Avatar
I had mine changed a wile back. I think the labor hrs were 6.
Coaster is offline   Reply With Quote
Old 10-20-2014, 05:04 PM   #8
well I got the car jacked up in my driveway. took most of the plastic undercarriage apart. it's dripping from the thermostate.
6 hours labor... screw that
Old 10-20-2014, 05:40 PM   #9
Artist, 986S tinkerer
NewArt's Avatar
Do it yourself. It's much cheaper and gives you a great feeling of accomplishment!
Old 10-20-2014, 06:16 PM   #10
It's a longshot, but do you have the updated expansion tank cap? Makes a big difference. Last week I had a leak by the rear passenger wheel. At 89,000 miles, I figured it was the water pump. Before I swapped it I checked the cap. It was an old one. Replaced with the new version and no leak. Problem solved for $30 and 2 minutes of time.
Phil C is offline   Reply With Quote
Old 10-20-2014, 07:03 PM   #11
yeah, I have the new one, and there's no vapor on the trunk lid. going to put it on ramps and swap out the water pump. 164XXX miles on her and now things are wearing out
Old 10-20-2014, 08:56 PM   #12
My 01 S had a coolant leak shortly after I purchased it. Engine temp never rose above normal, but the warning lamp blinked. Problem was the coolant tank.
DBear
dbear61 is offline   Reply With Quote
Old 10-21-2014, 07:01 AM   #13
I agree, sounds like the water pump. Since you'll be dumping coolant, I'd recommend installing the LN low temp T-stat while you're in there, especially based on your location; makes a big difference in coolant (read oil) temps.
JGM
2002 Boxster S
1973 911 Green FrankenMeanie
PCA DE Instructor circa '95
Old 10-21-2014, 07:24 AM   #14
was going to get a low temp to stat, but I'm unable to acquire one locally. already have the water pump and going to work on her after my midterm. time isn't a luxury for me.
Old 10-21-2014, 11:40 AM   #15
Guvs's Avatar
Hi phil.
I've just sent you a PM, and now notice while re-reading your thread that you have answered a few of my questions to you.
will be following this thread with intrest.
Guvs.
Guvs is offline   Reply With Quote
Old 10-21-2014, 12:51 PM   #16
sigh... auto parts store telling me the part is going to take longer because it doesn't have the gasket with it.... no pizza delivering for me today.
Old 10-22-2014, 01:48 PM   #17
water pump is off and waiting for the auto parts store to get the new pump. the blades on the old pump look like they were shaved off and one was broken. plus some lumpy corrosion was present. this job was pretty easy.
Old 10-22-2014, 06:47 PM   #18
Ouch! Wonder where all the blades are...
I'm doing mine in the next week. Got a very slight coolant loss last week (118k miles). I took a look at the pump and can see a slight mist coming out of the bearing area. Just waiting for the parts to come in.
did you do the job from underneath? Did you remove the motor mount?
Old 10-23-2014, 09:38 AM   #19
did the job from inside the car, pretty easy except for trying to put it back in without the gasket falling off. car is running fine, no leaks and coolant staying where it belongs. Idk where the one blade went but, luckily I fixed it at first notice.
Old 10-23-2014, 09:42 AM   #20
jsceash's Avatar
Great thanks for the update.
