Old 10-20-2014, 11:09 AM   #1
OBDII Fault Code Question
I had a CEL come on yesterday during a simple freeway run. Since I do not have a DME but only a OBDII scanner I plugged it in. The errors were P1126 and P1133.
I know what the error codes translate to, what I am scratching my head with is why one code, (1126), would say "Oxygen Sensing Adaptation Area 1 (Cylinders 4 - 6) - Rich Threshold", and the other "Aging of Oxygen Sensor Ahead of Catalytic Converter (Cylinders 1 - 3) - Below Lower Limit"?
So does this mean that one side of my engine is running lean and the other rich? Or is it simply time to change them?
2001 2.7, 5 speed, 90,000 miles.
mgfranz is offline   Reply With Quote
