Old 10-17-2014, 06:39 PM   #1
engine shut off on startup until I gave her some gas
Hey I like some opinions on what's going on
I started the 2001 Boxster S and the engine came to life then went out immediately. No check engine light, dash was on with only the coolant light staying red.
I turned the engine off and on and the same thing happened'
3rd try I gave her some gas, just pushed the pedal 2 times and the engine stayed on and all was fine on the drive back.
Weird...there was no clicking. Is this a fuel pump issue or just fuel vapors?
I'm not sure why I even pushed the fuel pedal...just a stab in the dark. I'm glad it worked.
Any thoughts is appreciated.
cbbepop is offline   Reply With Quote
Old 10-17-2014, 08:11 PM   #2
Artist, 986S tinkerer
NewArt's Avatar
Was the car warm ( i.e. recently run?)
Old 10-17-2014, 08:20 PM   #3
yes she was sitting around for an hour (came back from work)
then I started her up to go out get some beer and that's when the incident occurred.
Old 10-18-2014, 03:48 PM   #4
kinda worried now
Today every time I start i no longer have the engine go off on me but there is a weird "sucking noise" at start up kinda like air going through a torn valve. This noise is only occurring after I did the whole gave it gas while turning the ignition key thing last night.
Old 10-21-2014, 08:33 PM   #5
The engine stopping has happened to me once, I didn't do any investigating and it's been months since then and it's been running fine. I would definitely look into the valve though, but know that they just might be unrelated issues.
cypher279 is offline   Reply With Quote
Old 10-23-2014, 11:01 AM   #6
Took it to the dealership. they said fractured coil packs and a sticky plate could be to blame. Estimate $1400 because of the zeintop in the way and costed more labor than expected
Old 10-23-2014, 02:15 PM   #7
Now they say the sucking noise at startup is the starter. A quick google on boxster starter issue leads me to believe that they are correct. However its another $700
so there we go problem solved
Old 10-23-2014, 02:45 PM   #8
NewArt's Avatar
Starter at ECS: $261. Man, you're gonna have to get your hands dirty if you want to run an old Porsche!
Old 10-25-2014, 10:28 AM   #9
wow ecs is a gold mine. The dealership is still charging $500 just for the starter
Old 10-25-2014, 12:26 PM   #10
Ignition coils $43 at Pelican. Maybe cheaper at Sunset.
6 x $43 = $258
They are changed from the side through the wheel wells, so you don't have to take off the Zeintop. I could change all of mine in an hour with only a floor jack.
No idea what the "sticky plate" is.
clickman is online now   Reply With Quote
Old 10-25-2014, 09:11 PM   #11
6 x $43 = $258
Thanks for the info. I am gonna have a talk with them Monday when I get the car back. I imagine the dealership would say they needed the top off to make a full diagnosis of the engine cutting out and not just drop the engine from the underside. What can anyone say to that.
Old 10-26-2014, 09:52 AM   #12
The first thing they should be doing is connecting the car to their PIWIS or PST2 and dropping all codes.
No guessing allowed by a dealer's shop!
