Old 10-14-2014, 10:05 AM   #1
Wheel Bearing Replacement - What can go wrong ?
Hi ... I have a 2000 2.7 with approx 86K kms on the OD. I am very sure there are a couple of wheel bearings that need replacement. I get the typical sounds when turning a corner and the road noise is obvious. I'm in Toronto and store the car in the winters (usually about mid Nov). I've put quite a bit of $$ into the car this year (transmission and IMS bearing) and I'm considering putting the bearing replacement off until next spring. My question is what could possibly go wrong if I drive the car for the next 3 weeks without replacing the bearings. My tires already have 15K + on them so if they wear I'm not overly concerned ... what other risks do I run ?
And416 is offline   Reply With Quote
Old 10-14-2014, 10:53 AM   #2
you can likely put it off until the spring...... of course that is not a guarantee and if it gets worse you'll know
oldboxster is offline   Reply With Quote
Old 10-14-2014, 06:35 PM   #3
You'll be fine. It's just noise telling you that they're needing attention. Put it away, read up on it and do it next spring. This is a low $$ DYI as the bearings are $40-$50 each. Labor can be expensive as theirs some time involved in the R/R.
dghii is online now   Reply With Quote
Old 10-15-2014, 07:32 AM   #4
Thanks very much for your feedback
Old 10-15-2014, 07:38 AM   #5
JayG's Avatar
Might be a good DIY project and keep you bonded with your car over the winter.
You will have plenty of time to get it done
Old 10-15-2014, 09:18 AM   #6
Absolutely ... I've been searching the old threads and trying to figure out where I can get the right tools to to this job. Lots of good advice in the archives.
