Old 09-29-2014, 01:34 PM   #1
Talking Which Philips LED Day (drl) Lights for my 986 ?
I'm new to the forum but have owned a 1999 986 boxster for 3 years. I'm in need of some knowledge / help 😫 on my latest project!! Want to source, buy and fit LED day (drl) lights but really not sure what to go for.. The philips day light 8 or 9 DRL seem good OEQ but I'm also torn between the philips luxeon day light guide LED's?! I'm not even sure of the difference as there are no reviews ! I just know the luxeon day light guides ate the most expensive 😬 If you have any knowledge or experience of any of these products or just general advice to pass on, it WILL be much appreciated!! Ta!!!
98610 is offline   Reply With Quote
Old 09-29-2014, 01:53 PM   #2
JayG's Avatar
I was looking at those as well. Instead I did the fog light relay hack and use my fog lights as DRLs. I did change the H7s to LEDs
Do a search and you should fine some more info on both the Phillips LEDs and the hack
Old 09-29-2014, 10:27 PM   #3
chipmunk's Avatar
You need to find something that will fit the air intake. There are a number of posts on here and boxa.net on DRL installations.
This is what I fitted to mine - a single row of LEDs that were the brightest I could find.
2003 Boxster S
chipmunk is offline   Reply With Quote
Old 09-30-2014, 09:53 AM   #4
evo-r's Avatar
I wired mine to the parking light and I removed the parking light bulbs (last picture was before the bulbs removal)... http://986forum.com/forums/general-discussions/46857-%40%40-cob-led-drl-%40%40.html
His: 2003 Boxster & 2008 MDX
Hers: 2011 Golf TDI
evo-r is offline   Reply With Quote
Old 10-01-2014, 05:41 AM   #5
I have the Philips 4 LED strip...small, bright, fairly inconspicuous when not lit. I have the newer 986.2 bumper so not sure how they would look/fit on the 986.1
I installed the relay that turns them off when the headlights go on. I also added a dash switch to turn them completely off.
Name:  front_lip (Small).jpg
tomonomics is offline   Reply With Quote
Old 10-01-2014, 10:08 AM   #6
Cheers for all the help & responses so far.. I'm slowly but surely making my mind up ! Chipmunk...which lights are those? Look great, exactley what I'm looking for! Look similar to the philips day light guides which are a single row of LED's? Cheers 👍
Old 09-05-2021, 07:17 AM   #7
How did you run the wires from the lights into the front trunk? I have a 2003 and do not want to remove the bumper as I am sure 18 years has corroded most of the fasteners. Any thoughts would be appreciated. Also how did you attach the lights to the vent?
dragonflyoh is offline   Reply With Quote
