09-16-2014, 05:21 PM
#1
A very strange occurence
As some of you may have read I swapped out my HVAC control for a used one and it did not work properly, no AC compressor. I then swapped back in my original and it was then I noticed I have no instruments...zip no dash lights , no Tach...Zip.....any thoughts on this ??
I am checking fuses now and am yet to find a bad one ???
Dwight
09-16-2014, 05:48 PM
#2
I found it, simple B1 fuse 15A. It did not look bad but it ohmed out to be open, put in a spare and there you go.....just goes to show do not trust a visual check.
09-16-2014, 06:21 PM
#3
Glad that it was something simple
2001 Boxster S Lapis Blue
iPad Mini Dash Install
DEPO Tail Lights
09-16-2014, 06:28 PM
#4
I am my own mechanic....
Did that solve the no heater issue?
'08 VW Touareg T-3 wife's car
09-16-2014, 06:31 PM
#5
Went back to my original
it works fine, just missing a segment or two and a rising sun (from the west)
09-16-2014, 07:25 PM
#6
2003 S, 6 Speed, PCM, PSM, Bose, Litronics with washers, on its' second LN IMSB, comfort top, UDP, 987 engine mount, 997 RMS, Koni Sport Shocks, H&R springs, Techno brace, comfort blinkers, nin8six windscreen, particlewave light up cubby
09-16-2014, 08:50 PM
#7
Disassembled both units
The unit I got in was for a 99 and I have a 01, the only difference in the part numbers was the last digit. They were completely different inside from a PC board layout.
