Old 09-16-2014, 05:21 PM   #1
Pdwight's Avatar
A very strange occurence
As some of you may have read I swapped out my HVAC control for a used one and it did not work properly, no AC compressor. I then swapped back in my original and it was then I noticed I have no instruments...zip no dash lights , no Tach...Zip.....any thoughts on this ??
I am checking fuses now and am yet to find a bad one ???
Dwight
Old 09-16-2014, 05:48 PM   #2
Pdwight's Avatar
I found it, simple B1 fuse 15A. It did not look bad but it ohmed out to be open, put in a spare and there you go.....just goes to show do not trust a visual check.
Old 09-16-2014, 06:21 PM   #3
BruceH's Avatar
Glad that it was something simple
2001 Boxster S Lapis Blue
iPad Mini Dash Install
DEPO Tail Lights
Old 09-16-2014, 06:28 PM   #4
I am my own mechanic....
Timco's Avatar
Did that solve the no heater issue?
'08 VW Touareg T-3 wife's car
Old 09-16-2014, 06:31 PM   #5
Pdwight's Avatar
Went back to my original
it works fine, just missing a segment or two and a rising sun (from the west)
Old 09-16-2014, 07:25 PM   #6
Coaster's Avatar
Replacement 986 LCD screens.
996/986 LCD Display unit wth connectors (replacement kit)
Coaster is offline   Reply With Quote
Old 09-16-2014, 08:50 PM   #7
Pdwight's Avatar
Disassembled both units
The unit I got in was for a 99 and I have a 01, the only difference in the part numbers was the last digit. They were completely different inside from a PC board layout.
