Old 09-07-2014, 10:37 PM   #1
Tucker2's Avatar
Windshield Wiper Knob....removal
Ugh...I feel like I'm going to get blown up...but I can't figure out how to remove the windshield wiper controller knob in my '02. I pulled on it pretty hard and nothing so I started searching and...nothing.
Any advice is much appreciated.
Current: 981 Cayman
Former: '02 BS and '08 C
Tucker2 is offline   Reply With Quote
Old 09-08-2014, 07:19 AM   #2
I asked the same question here several months ago. I did not get a response either. I hope someone can help. I want to check to see if the controller is connected or if the relay needs replaced.
2016 4Runner TEP
Muzzle of Bees is offline   Reply With Quote
Old 09-08-2014, 07:22 AM   #3
Coaster's Avatar
Scary hard to pull off. I use both hands and pull straight back. Make sure you don't pull the trim piece behind it too hard. It has four clips that lock it in place, one is larger than the others to clock it (easy to tell which way it goes because the symbol on front should be right side up and level).
2003 S, 6 Speed, PCM, PSM, Bose, Litronics with washers, on its' second LN IMSB, comfort top, UDP, 987 engine mount, 997 RMS, Koni Sport Shocks, H&R springs, Techno brace, comfort blinkers, nin8six windscreen, particlewave light up cubby
Coaster is offline   Reply With Quote
Old 09-08-2014, 09:37 PM   #4
Tucker2's Avatar
Seriously? OK. Wow. Many thanks. I'll try this weekend.
Current: 981 Cayman
Old 09-09-2014, 08:01 AM   #5
Coaster's Avatar
Maybe there's another way to do it, I don't know. I did the same search as you, since at some point I'm going to change my lighting to blue, and eventually I just tugged it off revealing the amber light behind it.
