Old 09-08-2014, 07:22 AM   #3
Coaster
Coaster's Avatar
Scary hard to pull off. I use both hands and pull straight back. Make sure you don't pull the trim piece behind it too hard. It has four clips that lock it in place, one is larger than the others to clock it (easy to tell which way it goes because the symbol on front should be right side up and level).
2003 S, 6 Speed, PCM, PSM, Bose, Litronics with washers, on its' second LN IMSB, comfort top, UDP, 987 engine mount, 997 RMS, Koni Sport Shocks, H&R springs, Techno brace, comfort blinkers, nin8six windscreen, particlewave light up cubby
Coaster is offline   Reply With Quote
