Old 09-03-2014, 06:47 AM   #1
Car key, wiper problem
Hi guys, yesterday after a short ride, I stopped the car and I felt that taking out the car key went a little strange, I had to wobble the key a couple times and then I could pull it out. Today I tested the key issue, so shut it down again and tried to get the key out. It worked but not as smooth as before I had the problem. On my way to work. I wanted to use the windshield washer to wipe the windshield clean and... the windshield washers are not working..., I tried the wipers, they don't work! I'm like what is this? My first thought was, it must be a fuse. But when I stopped at a gas station to fuel up, was done with it started the car again, everything worked just fine again like nothing ever happened, just the key problem is still there. So what I am thinking now is that the key problem has something to do with the washer problem. Could it be that the ignition switch is the problem behind all this? Anybody experienced something similar? My Boxster is a 2003.
jeffdehaes is offline   Reply With Quote
Tags
car key , ignition switch , wipers
