Old 09-02-2014, 05:00 AM   #1
newob's Avatar
Engine is dieing and throttle is less responsive
So I finally got my boxster s back from the shop and I have noticed and increase in a Problem that was somewhat present prior to my little fender bender.
The engine keeps dieing at low revs. Basically if I take it out of gear and coast into a stoplight the engine will cut out. Also when I first drive it when it is cold, the exhaust is a bit smokey.
This morning while driving to university I found that the throttle was also not responding very well. I would mash on the gas and it would not rev very quickly and it would do it jerkily? Idk it was weird.
My first thought is throttle body?
Perhaps if I run some carb cleaner stuff in it with the gas it would help?
Once it is warmed up it seems to do ok except for the stalls at lights.
How do I clean my throttle body?
2000 Boxster S
newob is offline   Reply With Quote
Old 09-02-2014, 03:28 PM   #2
Spinnaker's Avatar
Try the E-Gas reset first.
http://986forum.com/forums/general-discussions/20145-when-i-step-gas-my-boxter-nothing-happens.html
Old 09-02-2014, 06:19 PM   #3
Perhaps a clogged fuel filter?
guesswecan777 is offline   Reply With Quote
Old 09-02-2014, 06:33 PM   #4
Mass Air flow sensor?
OklahomaBoxster is offline   Reply With Quote
Old 09-02-2014, 06:34 PM   #5
or air/oil seperator
Old 09-02-2014, 06:38 PM   #6
Porsche man's Avatar
Mass air flow sensor. Had the same problem. Pulled it out and sprayed it with special spray and all fixed.
Porsche man is offline   Reply With Quote
Old 09-03-2014, 11:52 AM   #7
You need to look at the codes with a durametric and get back.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 09-03-2014, 02:22 PM   #8
newob's Avatar
Clean throttle body and mass air flow sensor
Well i spent most of the day working on my car. to clarify, it was not throwing any check engine lights or anything.
So what I did was take out the air filter, (which was absolutly disgusting!!!!!!!!!!) and then I bought some mass air flow spray at O'reilly's, and also some throttle body spray. cleaned my throttle body and mass air flow sensor, and then also put an additive (seafoam) in my gas to clean my fuel injectors etc.
Car runs fantastic!!!
has more power then i have ever felt in it period!!!! so responsive! and it idles like a purring tiger.
:dance::dance::dance::dance::dance::dance::dance:
I followed pelican parts information about how to do all of this. Just takes time and patience. And I ordered a new air filter (the old one is back in it now, but has been cleaned to within an inch of its life)
2000 Boxster S
Old 09-04-2014, 08:35 AM   #9
This is exactly what I'm experiencing!!! Newob, Thanks! I'll be doing this for sure!
The guy at advanced showed me where the Mass Airflow sensor is, but I don't know where the throttle body is. Also, I heard you can damage the sensor if you don't handle it properly?
Any tips or advice? I could expect to spend 6-8 hours doing this?
rock88hard is offline   Reply With Quote
Old 09-06-2014, 07:01 AM   #10
Look for the online guides for throttle body cleaning. Should be a 30 minute job but since the guy at advance auto parts is showing you where stuff is on your porsche I dont know lol.
