Old 03-11-2006, 02:59 PM   #1
What's that smell???
My Boxster has about 500 miles on it and every time I get out there is a smell that I can't put my finger on. Is it possible that it is my clutch or brakes or is it some coating that new cars burn off?
______________________
2005 Porsche Boxster
2007 Lexus LS460
2004 Lexus RX
luxury1 is offline   Reply With Quote
Old 03-11-2006, 03:34 PM   #2
bmussatti
Posts: n/a
Hey Luxury, you need to start driving that yellow beast, and get out of the break-in period...so you can see the brighter side of 4,500 RPM man!!
The smell could be any one of those things. Does it smell that way after a normal easy drive or a spirited one? If after just a normal drive, it could be some of the protective coating. But, if after a spirited drive, you might be slipping the clutch a little too much.
Old 03-11-2006, 07:32 PM   #3
Could it be your tires?
Old 03-11-2006, 09:40 PM   #4
If it smells like burning rubber and happens after the car's been run for a while, it may be a small oil leak -- so small that you don't even see it on the garage floor. I understanding burning synthetic smells this way. I recall that there there have been postings on PPBB about this. Check it out in their archives.
longislander1 is offline   Reply With Quote
Old 03-12-2006, 09:16 AM   #5
Send a message via AIM to bhduxbury
my 3-mo-old 987 had a "burning plastic" smell after operation for awhile -- noxious and "fumey" -- it was still there at 700mi -- but i haven't noticed it in a while -- dunno when it resolved specifically but i'm at 1500mi now fwiw -- couldn't tell you what it was
bhduxbury is offline   Reply With Quote
Old 03-12-2006, 12:55 PM   #6
Brucelee's Avatar
Talking
Every Porsche that I have ever stocked has a bit of an odor when the engine has been run a bit.
The 911 is worse, as the motor sits right out in the butt end.
Normal as far as I can see.
Rich Belloff
Old 03-12-2006, 07:31 PM   #7
just got back from a drive -- i used to notice the burning plastic smell when i exited the car -- big whiff of it -- i thought it was gone at 1500, as i said above, but today i poked my head down to the side intake -- the smell is still there -- but nowhere near as pronounced as at 500.
Old 03-13-2006, 06:00 AM   #8
I have noticed it during all driving but including normal driving (not too hard) and I am pretty sure it is not the tires. Maybe it is just a normal smell of the engine since the intake is right at the door. I will keep a nose on it and let you guys know if it keeps doing it. Thnaks for the advice!
2007 Lexus LS460
2004 Lexus RX
Old 03-13-2006, 09:41 AM   #9
probably the adhesives that glue the engine compartment insulation to the body
insite
'99 Boxster
3.4L Conversion
Old 03-13-2006, 10:22 AM   #10
Usually new exhaust components will smell funny when exiting the car for the first week of driving. What you smell is the oil/grease used to lubricate the bending machines while bending the exhaust tubes. Sounds like your problem has been longer than a week and therefore would not be this very normal occurrance.
KRZ
http://x402.putfile.com/2/5800280187-thumb.jpg
Voghtland 30-50mm Coilovers
19x8.5 x 19x10 Forgline rims
Magnaflow Exhaust
KRZTACO is offline   Reply With Quote
