Old 08-11-2014, 08:35 AM   #1
Has anyone moved a Boxster on a U-haul carrier?
I need to move about 1-2 small rooms of stuff and my Boxster about 1400 miles. I was considering a U-haul truck with a carrier behind it.
Has anyone her ever put a Boxster on one of those? There are ramps to drive up, but I'm not sure of the clearance on the trailer. It looks like there are straps that go around the front tires, and a safety chain front and rear that you put on something underneath.
Thanks for any info!
DG Boxster is offline   Reply With Quote
Old 08-11-2014, 09:03 AM   #2
I have used the trailer for another car an older IROCZ. what you can do to get around the ramp issue is to either get long boards for the ramps, or you can put the ramps so they extend onto a sidewalk and drive on that way. (both are detailed pretty well online) the iroc is probably harder than a Boxster, as there is a chance you could just back the boxster on as the ramps sit.
HOWEVER, I would consider not doing this with your boxster if you have to go far. Mainly, there are tons of rocks and pebbles that pelt your car as it is being carried.
Old 08-11-2014, 09:09 AM   #3
ppbon's Avatar
The U-Haul trailers are not good for Boxsters.
They have very high tire guides that will destroy the bottom panels.
The Penske trailers on the other hand, are perfect fore the Boxster.
Happy Boxstering,
Pedro
Racecar spelled backwards is: Racecar!
ppbon is offline   Reply With Quote
Old 08-11-2014, 10:01 AM   #4
Track rat
Topless's Avatar
I rented a U-haul trailer once and used 2x6 boards to raise the car for clearance. It still had stock suspension at the time and I probably would not do it now that the car is lowered.
Old 08-11-2014, 11:44 AM   #5
DennisAN's Avatar
It may be better to buy a 1-way air fare back and just drive the Boxster to the new home.
Base 2000 986, beater 1996 Miata, 2011 Suzuki SX4 AWD
Feline mechanics Condoleezza and Dukie
DennisAN is offline   Reply With Quote
Old 08-11-2014, 03:56 PM   #6
Joe B's Avatar
Not true. I used a U-Haul trailer to haul my Boxster from Boise ID to Jackson, WY and it worked fine. The only thing I did was put some 2x6s under the front tires so the front bumper cover would clear the front wheel stops. I have ROW MO30 suspension and had no trouble getting on or off. But if you can find a low spot for the trailer wheels to rest in, it does decrease the ramp angle.
Old 08-11-2014, 09:55 PM   #7
What about sending the car on a covered carrier? Can anyone recommend one?
Old 08-12-2014, 11:48 AM   #8
Box4two's Avatar
I'm planning on using a Uhaul in December from Toronto to Florida so I can have the Boxster with me while I'm there for a month.
Previous 2 seaters:
1975 Triumph TR7
1979 Fiat X19
1977 Lotus Esprit
Honey it's an investment!
Box4two is offline   Reply With Quote
Old 08-12-2014, 02:25 PM   #9
Not a U-Haul, but worked pretty well!
2001 Lapis Blue Boxster S Tip (stock), 2001 Guards Red Boxster 5-speed (not very stock)
tightbox is offline   Reply With Quote
Old 08-12-2014, 02:28 PM   #10
Perfectlap's Avatar
Aren't there Ebay Motors shippers that will do this for like $700?
p.s.
Check with your insurance on coverage when you're car is the passenger...
BORN: March 2000 - FINLAND
Old 08-12-2014, 07:03 PM   #11
ppbon's Avatar
That's why I "love" the Internet ...
... You try to help someone with your experience and someone else calls you a liar. Happy Boxstering
Pedro
Originally Posted by Joe B View Post
Not true
Old 08-12-2014, 08:30 PM   #12
Pedro
Pedro - thanks for trying to help me. I saw those high rails on the video on the U-Haul site and thought they might be trouble. I'm going to try to find a trailer with low rails.... or just drive the Box.
Old 08-13-2014, 06:14 AM   #13
Joe B's Avatar
Pedro
I didn't call you a liar! A liar is someone who intentionally misleads. It is possible to simply be wrong. My experience shows that U-Haul trailers are ok for Boxsters.
Don't be so sensitive ! Happy Boxstering to you too !
Old 08-13-2014, 07:37 AM   #14
Your picture is inspiring! I'm gonna check it out. Quotes for a truck and trailer for my move are about $1800 plus gas, and these trucks seem to get "6-10 mpg"
That's getting into the range where I can just get a PODS for my stuff and drive the Boxster.
Old 08-13-2014, 10:17 AM   #15
ppbon's Avatar
My experience ...
... multiple times with U-Haul trailers is contrary to yours.
What I stated above (and below) is completely accurate.
I have had to repair several Boxsters that we're damaged by such trailers, including mine when it was the only trailer option available.
If you disagree with someone's comments just say so.
Don't state that their comment is not true because that implies that it's a lie.
When my character is challenged publicly I will stand up.
Happy Boxstering
Pedro
Old 08-13-2014, 01:46 PM   #16
Joe B's Avatar
Happy Boxstering
Pedro
Sorry if I insulted you or hurt your feelings!
I didn't mean to imply anything about intentional lying, except that I disagreed because I had no problems with a U-Haul trailer, even with my lower Boxster. Perhaps I should have said "Not true in my experience," but I thought that was clear from my post. Maybe I used a different model of U-Haul trailer? (Please be sure to correct any inaccurate information that you ever feel I may offer. I appreciate being corrected if I'm wrong ! And no, I'm not implying anything .)
Happy Boxstering to you!
Joe
