Old 08-09-2014, 11:49 PM   #1
Breaker's Avatar
Lightbulb Daylight Running Lights
Hi all,
I have been thinking of fitting a set of daylight running lights to my 986, has anyone here done this and can recommend some (pics are always welcome)
Breaker is offline   Reply With Quote
Old 08-10-2014, 06:05 AM   #2
On the slippery slope
JayG's Avatar
an easy thing to do is use the fog lights as DRLs
Its a 5 min install for the wiring and only costs a couple of $
I also swapped out the H-7 bulbs for LEDs ~ $40 on ebay
2X White Bulbs H7 Car Genuine CREE XB D LED Fog Light Lamps Headlight | eBay
Daytime running lights hack
DRL-Fog Light Hack - 986 Series (Boxster, Boxster S) - RennTech.org Forums
If you want to add LED strip DRL, this is a nice package
http://www.amazon.com/dp/B005DX6BKW/ref=wl_it_dp_o_pd_nS_ttl?_encoding=UTF8&colid=3HC0TWCL7KNZJ&coliid=I25UOME3IV8CIO
2004 996 Targa Tip
Instructor - San Diego region
Old 08-10-2014, 06:25 AM   #3
I am my own mechanic....
Timco's Avatar
The Litronics have a marker light. Comes on with parking lights. I just use those. Love the dim lit look of the headlight marker lamps. They stay on with the main headlights to make 2-tone.
'08 VW Touareg T-3 wife's car
Old 08-10-2014, 09:35 AM   #4
Breaker's Avatar
Do you have a link Tim?
Old 08-10-2014, 09:57 AM   #5
Timco's Avatar
I do not. Just search for Litronic Xenon.
New these were $3200 per side after a lady backed into me. You can find them on eBay all day long and many other sites including Pelican.
Note. The 'Litronic' part means there's controls and parts that make the main lights self level. Some are just weighted or balance and are far less. Others will chime in on this.
Old 08-10-2014, 03:47 PM   #6
2002 Boxster S
How are these things wired in Canada, which has mandatory DRLs in all cars? Seems like they must have a simpler fix than fuse taps and jumper wires.
Canadians, can you comment?
2009 Carrera S cabrio
ex-2002 Boxster S, Arctic Silver, Aerokit II
silver-S is offline   Reply With Quote
Old 08-11-2014, 11:52 AM   #7
still plays with cars...
BoxsterSteve's Avatar
Simpler?
Not sure about that... but there is a double size dedicated DRL relay on the relay panel that illuminates all exterior lights while the car is running. The only thing my headlight switch does is turn on the gauge illumination.
Six speed 2000 Boxster S
Old 08-15-2014, 04:19 AM   #8
Guvs's Avatar
Here are my after market ones.
Guvs.
Guvs is offline   Reply With Quote
Old 09-01-2015, 11:36 AM   #9
01BOXYS's Avatar
Guvs.
I see this thread is a little over a year old but I was wondering where you got those LED lights and how hard were they to mount? These look great
2001 Boxster S Arctic Silver : LN IMS Retrofit, Sport Package, AUX cable mod, de-snorkeled.
01BOXYS is offline   Reply With Quote
Old 09-01-2015, 01:03 PM   #10
I have two lines of DRLS
99 Porsche Boxster 986 3.8
85 Toyota Corolla AE86 F20C
12 Honda Accord
16 Mercedes C450 AMG
22 Tesla Model X Plaid
Old 09-01-2015, 02:17 PM   #11
Old thread, but what the heck...I'll post my DRLs.
Old 09-01-2015, 04:04 PM   #12
Pdwight's Avatar
I like those....best retrofit I have seen so far
Old 09-01-2015, 05:29 PM   #13
Artist, 986S tinkerer
NewArt's Avatar
I just ran a jumper wire in the fuse panel (see DRL hack threads) to make my fog lights turn on with the ignition. I swapped out the fog light bulbs for DELs from ebay. Easy, cheap, and effective!
Old 09-01-2015, 05:44 PM   #14
Thanks Dwight!
Old 09-01-2015, 05:51 PM   #15
Pdwight's Avatar
DEL's ??? im slow
Old 09-01-2015, 10:40 PM   #16
oldskool73's Avatar
DEL's ??? im slow
Like LED's, but you mount them backwards :P
oldskool73 is offline   Reply With Quote
Old 09-02-2015, 04:40 PM   #17
NewArt's Avatar
Haha. I get my english and french mixed up! LEDs is right.
Old 09-02-2015, 04:44 PM   #18
Beginner
Jamesp's Avatar
Ahead of their time. Current LED's look terrible because they draw attention to themselves. They will be outdated in six months. This understated approach is classic.
2003 S manual
Old 09-02-2015, 05:29 PM   #19
Thanks James
I like the softer glow of the integrated CCFL...
Old 09-02-2015, 06:11 PM   #20
lkchris's Avatar
LED Daytime Running Lights and add-on LED lighting for interior or exterior car use.
Also, think about the notion of "DRL Controller"
Want to improve your Daytime Running Lights? Now you can with the DRL Controller!
The excellent Daytime Running Light Controller is a must have essential for anyone who owns a DRL. The Audi style controller is designed to adjust the DRL brightness when headlights or sidelights are switched on to prevent glare and also your indicator light will switch off the corresponding side of the DRL lights to help other road users clearly see your intensions.
How it works:
•The DRL controller cannot be tested on a standard 12V supply it must be connected your vehicle battery. See instructions.
•After starting your engine both DRL lights will switch on automatically.
•When you switch your headlight bulbs on the DRL lights will decrease in brightness by 40% automatically to prevent glare.
•When using your indicators the corresponding side of the DRL lights will switch off automatically and once the signal light has turned off the DRL light will switch back on automatically.
•Once your engine is completely off the DRL lights will turn off about 40 seconds later.
Kent Christensen
Albuquerque
2001 Boxster
2007 GL320 CDI, 2010 CL550
2 BMW motorcycles
Tags
lighting
