Old 08-05-2014, 11:09 PM   #1
No electrical power
New battery installed drove car to work,8 hours later car dead as a nail could not get hood open,When hooked up to fuse box positive post pull out .Tried charging threw the pull out nothing can't get hoods to open .
Last edited by the1andonly; 08-06-2014 at 03:51 PM. Reason: Put jump start by mistake
the1andonly is offline   Reply With Quote
Old 08-05-2014, 11:48 PM   #2
Bruce Wayne's Avatar
new battery could be duff. Alternator not charging or something is drawing power ?
986 x2 6sp
2x Range Rover Vogue 4.6
2004 MX5 Sport 6speed Strato Blue (wifelet)
2x Range Rover Classic & CSK
Bruce Wayne is offline   Reply With Quote
Old 08-06-2014, 07:26 AM   #3
epapp's Avatar
How did you jump start the car without getting the hood open?
Was your battery light on while driving?
Old 08-06-2014, 07:41 AM   #4
Jumper connection in the footwell fusebox. It has a slide out connector for the positive.
986 x2 6sp
Old 08-06-2014, 07:54 AM   #5
epapp's Avatar
I knew you could charge from there, I didn't know it could also be used for jump
Old 08-06-2014, 10:29 AM   #6
Brad Roberts's Avatar
DONT jump START the car from there!! Just use it to to supply power for the trunks/hoods
Old 08-06-2014, 10:46 AM   #7
Pdwight's Avatar
What Brad said
I would never jump anywhere but the battery terminals, a tremendous amount of current is drawn on a jump start....you want that battery in line and absorbing all the spikes and noise that takes place. Use the auxiliary port to open the hood....but not to jump the car off
Old 08-06-2014, 11:29 AM   #8
i'm just guessing.. i cant think of anywhere someone may jump from
986 x2 6sp
