Old 08-02-2014, 04:28 PM   #1
2002 uk boxster alarm bleep?
So i have just got a 2002 boxster 2.7 loving it by the way, and every time i lock the car my horn sounds, and on 3 occasions in the last two weeks the alarm has gone off?
Any ideas? Ive checked the roof, bonnet, doors and trunk lids with no luck?
It does have an aftermarket radio if that matters? Ive been told it could be an issue.
Samp4856 is offline   Reply With Quote
Old 08-02-2014, 06:22 PM   #2
Steve Tinker's Avatar
Make sure the arm rest cubby compartment is closed / locked down securely.
Sometimes the hinge (@ the rear) breaks and stops the lid closing properly....
2001 MV Agusta F4.
Old 08-03-2014, 10:56 AM   #3
Bruce Wayne's Avatar
+1
Also the Boxster alarm system has a small contact switch located to the left side of the radio compartment that detects removal of the radio. In order to prevent the alarm from repeatedly going off, you need to connect this wire (brown / blue) to ground.
As an audiophile, i find the Becker CDR-22 fitted in mine as standard perfectly acceptable
986 x2 6sp
2x Range Rover Vogue 4.6
2004 MX5 Sport 6speed Strato Blue (wifelet)
2x Range Rover Classic & CSK
Bruce Wayne is offline   Reply With Quote
Old 08-03-2014, 06:40 PM   #4
M31
M31's Avatar
Originally Posted by Bruce Wayne View Post
+1
Here's a picture of that pesky little contact switch...
M31 is offline   Reply With Quote
Old 08-04-2014, 12:05 AM   #5
2004 2.7 Tip Lapis Blue
I got a 2007 2.7 Tip, same thing happens, every time I lock the car the alarm beeps once. I thought this was normal?
MadDad is offline   Reply With Quote
Old 08-04-2014, 12:08 AM   #6
Pdwight's Avatar
Neat
I learn something new every day
Old 08-04-2014, 01:08 AM   #7
mavis.d's Avatar
I have 2002 UK car and had the same problem after fitting a new head unit, however even when contacted to ground had the same problem. This was cured when the blue/brown wire was disconnected.
mavis.d is offline   Reply With Quote
Old 08-04-2014, 04:47 AM   #8
perfect thank you for your responces, ill have to try it, that wouldnt supprise me if that is the issue as i have checked every thing else and adjusted what i can i.e boot, door, and roof catches, and tried it with the center console locked and unlocked and still nothing, so hopefully this will cure the issue.
great forum help.
