Old 03-10-2006, 03:17 PM   #1
Unhappy 987 - Hood Locked
The front hood is locked on my 987 Boxster and there is no battery in the car. How do I open the hood to get the battery in.
roshanr is offline   Reply With Quote
Old 03-10-2006, 03:26 PM   #2
olly986
Guest
Posts: n/a
hi matey
there is a thread on the bottom of the forum page about hood cable that might help otherwise do a search and i am sure you will find something, it was mentioned lately, something to do with the hook screw cover in the front bumper.
hope this helps
see ya!
Old 03-10-2006, 03:37 PM   #3
call their 24 hr roadside assistance.
same thing happened to me.
newer boxsters need a doner battery to pop it open.
no other way around it.
its in the manual
2004 boxster s seal grey 6spd
steven choi is offline   Reply With Quote
Old 03-10-2006, 03:41 PM   #4
The lid can only be opened with the aid of a donor battery.
1. Use the key to unlock the vehicle at the door lock.
2. Remove plastic cover over the fuse box.
3. Pull out psitive terminal A in the fuse box.
4. Use a jumper cable to connect the positive terminal of the donor battery with positive terminal A in the fuse box. (it's marked with a little picture of a front lid being opened - feel free to envision yourself in the picture as well )
5. Use the second jumper cable to connect the negative terminal of the donor battery with latch striker B (the metal hoop in the door frame to which the door lock engages). - If the vehicle was locked the alarm horn will sound.
6. Unlock the front luggage compartment lid with the remote control to swith the alarm system off.
7. Disconnect the negative cable first, then the positive cable.
8. Push the positive terminal A into the fuse box and close the box cover.
Note:
If you're interested, the engine cannot be started with this method.
http://i7.tinypic.com/24ovngk.jpghttp://i7.tinypic.com/24ow0id.jpg
06 987S- Sold
Carrara White / Black / Black/Stone Grey Two-tone
05 987 5-speed - Sold
Midnight Blue Metallic / Metropol Blue / Sand Beige
06 MB SLK350- Lease escapee
Iridium Silver Metallic / Black
We've heard that a million monkeys at a million keyboards could produce the complete works of Shakespeare; now, thanks to the Internet, we know that is not true. - Robert Wilensky
SD987 is offline   Reply With Quote
Old 03-10-2006, 03:42 PM   #5
You can also goto an autoparts store that has a charger that plugs into your cigarette lighter. Once you plug it in, there should be enough juice to pop the latch open.
KRZ
http://x402.putfile.com/2/5800280187-thumb.jpg
Voghtland 30-50mm Coilovers
19x8.5 x 19x10 Forgline rims
Magnaflow Exhaust
KRZTACO is offline   Reply With Quote
Old 03-11-2006, 07:52 AM   #6
Thank You
You guys are great!!!! You saved my a couple of hundred bucks. I tried 3 dealers in Boston and each one wanted me to have the car towed in.
All I needed to do was hook up a battery to the positive terminal in the fused box as SD987 suggested in his post
Thank you
Old 03-11-2006, 11:09 AM   #7
Curious, why the need to replace the battery? Glad it was easy for you.
06 987S- Sold
Old 03-12-2006, 04:19 PM   #8
I removed the battery for winter storage. Had the battery on a trickle charger at home, while the car was in a public storage facility.
