Old 07-25-2014, 06:27 PM   #1
Hood not releasing, sometimes.
I use the front hood electronic release in the driver's door sill, I can hear the motor pull under the hood and 50% of the time the hood doesn't pop, but just sits there.
I have tried to recreate this, but sometimes it opens perfectly, sometimes the motor sounds like it moves the clasp, but nothing else happens up there.
The battery is fully charged. I have tried applying some pressure on the hood where the latch is to get the hood to pop. Nothing. I drive around and ignore it for 4 hours or sometimes a day, and viola, it opens up again.
Any ideas?
Also I hear there is an emergency cable. Is it behind the passenger headlamp? Isn't this a bad place for it since I need to be in the hood to get the headlight out to access the emergency cable?
Thank you!
'04 986 Aero - Seal Metallic Gray
Fabspeed: Maxflo Mufflers, Headers with sportcats, Tips; Alpine & Infinity sound
davemon is offline   Reply With Quote
Old 07-25-2014, 07:23 PM   #2
ChrisZang's Avatar
Do a search, this a known problem, there's many posts about it and how to fix it
Old 07-25-2014, 07:43 PM   #3
Multi-Boxer Driver
Deserion's Avatar
Funny, my '04 Seal Gray also has this issue. Now the frunk won't open without the emergency release (strategically relocated). Need to replace the actuator.
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
Old 07-26-2014, 11:07 AM   #4
What did you search to discover the fix to the hood not popping but the release motor is moving? I searched for "hood" in the thread titles, scrolled/read through 6 pages to 2007, but didn't find an exact remedy other than spraying WD-40 on the latch mechanism, in other threads folks with my similar problem said this didn't work either.
I know I can get in using the emergency cable, but I don't just want in once. I want the hood to pop electronically, every time I pill the switch on the door sill / push the key fob.
Has anyone replaced or had to replace the hood unlocking motor? If the motor is making noise every time but the hood only pops 70% of the time, might this be something else?
Old 07-26-2014, 11:08 AM   #5
Damn! Must be our punishment for having the best 986 model
