Old 07-11-2014, 01:17 AM   #1
2001 Boxster exhaust rattle
Help!!!
My Boxster has an odd exhaust rattle. Only present at peak temp, as soon as it idles for 30 seconds and cools down the rattle quiets.
I've worked with my local shop to rule out all heat shields. Replaced the muffler and header cats.
I've read just about every exhaust rattle post and just can't figure it out.
About to give up after spending months, huge $$$ and getting nowhere...
Any suggestions welcome...
Poeschel1 is offline   Reply With Quote
Old 07-13-2014, 04:48 PM   #2
myn8m3is8ndy's Avatar
i had a rattle for my 02 boxster. shop said it was the exhaust system but wasnt sure if it was the muffler or cats. i ended up just installing on a secondary cat bypass, or test pipes, whichever one you want to call it, and the rattle went away.
myn8m3is8ndy is offline   Reply With Quote
Old 07-13-2014, 11:27 PM   #3
Rattle or a squeak?
Mine squeaks when hot and it had the cat-delete mid pipes, everything seems rock solid mounting wise. I have heard it can come from either inside the cats (on the exhaust manifold) or a broken weld in the muffler itself. Very hard to figure out because of the crazy heat in the area while you are checking everything (and it has to be hot to make the noise). I don't want to have to replace my muffler since it has the Pedro's mod and it sounds glorious!
Chronohunter is offline   Reply With Quote
Old 07-13-2014, 11:29 PM   #4
mine squeaks when hot and it has the cat-delete mid pipes, everything seems rock solid mounting wise. I have heard it can come from either inside the cats (on the exhaust manifold) or a broken weld in the muffler itself. Very hard to figure out because of the crazy heat in the area while you are checking everything (and it has to be hot to make the noise). I don't want to have to replace my muffler since it has the Pedro's mod and it sounds glorious!
Old 07-13-2014, 11:30 PM   #5
Duplicate post sorry
Old 07-14-2014, 02:14 PM   #6
Usercpy
ilikeching's Avatar
Use a rubber hammer to tap thru exhaust, maybe you'll find the problem area..
http://www.flickr.com/photos/flickr_ching/
ilikeching is offline   Reply With Quote
Old 07-15-2014, 04:54 AM   #7
batshapedheart's Avatar
Originally Posted by Poeschel1 View Post
Help!!!
Ugh, I have this same issue. It started after I got my transmission rebuilt.
2002 Boxster 2.7
batshapedheart is offline   Reply With Quote
Old 07-19-2014, 08:15 PM   #8
After replacing the muffler and headers, it turns out it was the RH secondary Cat.
I replaced both mid pipes with Top Speed test pipes.
Problem solved!!!
Thanks for the responses.
Old 07-19-2014, 09:18 PM   #9
Problem solved!!!
That's great
