Old 07-10-2014, 03:20 PM   #1
Aftermarket deck driving me insane
Trying to install an aftermarket deck... Have a 2002 Boxster with door speakers and the front amp. Used the metra adapters... And all I get is Sub... Nothing out of speakers. Really pissing me off. Deck is a Pioneer MVH-X360BT.
Any ideas?
ToXicXxX is offline   Reply With Quote
Old 07-10-2014, 06:08 PM   #2
KevinH1990's Avatar
Can you provide more information on how you wired it up? There are several possibilities:
1. You didn't hook up the wire that turns on the amp
2. You used the outputs from the head unit that are designed to go directly to the speakers instead of the outputs designed to go to the amp
3. There is some damage to the headunit
Good luck with your project.
Old 07-10-2014, 08:03 PM   #3
BruceH's Avatar
Make sure the pins are matching up with what is in the Pelican article here:
Pelican Technical Article: Changing Your Boxster Stereo Head Unit / Installing Boxster Ipod Integration - 986 / 987
2001 Boxster S Lapis Blue
iPad Mini Dash Install
DEPO Tail Lights
