Old 07-10-2014, 06:08 PM   #2
KevinH1990
KevinH1990's Avatar
Can you provide more information on how you wired it up? There are several possibilities:
1. You didn't hook up the wire that turns on the amp
2. You used the outputs from the head unit that are designed to go directly to the speakers instead of the outputs designed to go to the amp
3. There is some damage to the headunit
Good luck with your project.
