Old 07-03-2014, 09:58 AM   #1
Coaster's Avatar
Can I drive my car without...
the radio, climate control unit, window/PSE/top/lock/defrost switches installed?
If I pull these out to work on them and it takes a while (or God forbid, I screw something up) can I drive my care without messing up the computer/security/etc if these things aren't installed?
I'm guessing I'll have to have the instrument cluster installed
Coaster is online now   Reply With Quote
Old 07-03-2014, 11:05 AM   #2
Except for the PSE switch (I don't have one), this is how I drove my 2001 S for a week while repainting the interior trim a couple of weeks ago. I didn't even have the center console installed.
I only re-connected the top and window switches in case I needed them, everything else was disconnected. You'll just need your radio code when re-connecting the radio (assuming you have a Becker).
fab986 is offline   Reply With Quote
Old 07-03-2014, 11:47 AM   #3
Should be fine. PSE should default to "off" as usual.
I don't have any of these switches in my Spec Boxster race car and everything is fine with the stock ECU and immobilizer.
