Old 06-29-2014, 05:51 PM   #1
Craig's Avatar
Need Trans. help please!!!!
OK I have a 2003 Boxster S. I noticed some tripping from under the car and saw I had a torn CV boot. Saw I decided to replace them. So, while in right there I also recall during my last DE the tranny was shifting kind of harder than usual, so I though I should change the fluid. When I pulled the plug (near the back of the trans.), nothing came out!!!!! This is really odd since the car does not leak any fluid. So I get my 101 book out and none of the pictures look like my tranny. So near the back of the trans. I see what looks like the fill port, but it is a 13 mm bolt that is about 1 1/2" long. I try to inject fluid through this hole and it goes in.....all 4 quarts!!!! So I decide to pull the drip pan off to get a better look at what is going on. I do see what could be a fill plug on the pass side near the top. I can't get any allen wrenches to fit so I used a pair of vice grips to remove the plug. When I got it out. It has what looks like a magnetic end sticking out. When I looked inside the trans. I can see that this slides into some type of hole. then I saw the hole slide down inside the trans. And I don't know how to get it back up AUUUGGRRRR!!! below are some pictures.
Craig is offline   Reply With Quote
