Old 06-27-2014, 06:53 PM   #1
jim_hoyland's Avatar
Odometer Accuracy
Has anyone verified the accuracy of the Boxster odometers ? Reason I ask is because many, if not all, early 986's have speedometers that read about 3 mph lower than actual.
jim_hoyland is offline   Reply With Quote
Old 06-27-2014, 07:34 PM   #2
Damn Yankee
TeamOxford's Avatar
My experience with older Boxsters indicates that the speedos register 4 MPH ABOVE the actual speed (as calculated by a GPS receiver). After 100 MPH, it goes up to 5 MPH above.
Just sayin'............
TO
Old 06-27-2014, 07:35 PM   #3
On the slippery slope
JayG's Avatar
Don't you mean faster than actual?
A speedo that reads slower than actual from the factory would open them up to litigation from people that got speeding tickets. Also IIRC, there is some law in Germany that they cant read slower then actual
2004 996 Targa Tip
Instructor - San Diego region
Old 06-27-2014, 07:35 PM   #4
Multi-Boxer Driver
Deserion's Avatar
Speedometer display =/= odometer display.
Speedometers are generally set to read a little higher than actual speed, whereas odometers are set to be as spot-on as possible.
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
Old 06-27-2014, 08:10 PM   #5
I had it backwards: speedo reads higher than actual. Some previous posts indicate this question was addressed and tested. Odometer is accurate even though the speedo reads higher
Old 06-27-2014, 08:26 PM   #6
The odometer on my 2000 is spot on. I measured a known to me mile and it was perfect. My speedometer indicates faster than my actual speed by 3 or 4 mph depending on my speed.
SoCalBlackbox is offline   Reply With Quote
