Old 07-19-2014, 08:21 AM   #81
tanque55's Avatar
Seal grey 2002 S bought Aug 2012 39,000 miles.
tanque55 is offline   Reply With Quote
Old 07-19-2014, 11:42 AM   #82
Porsche9's Avatar
Bought her less then year ago with 41k and now she is approaching 51k. I've done the water pump, ignition switch IMS, RMS, and oil changes. I also added az hardtop for the hot Phoenix summer.
03 Carrera
89 Carrera 4
89 944 S2
78 911SC
Old 07-24-2014, 04:46 AM   #83
mikesz's Avatar
Bought 02-15-13 with 75k just turned 80k. 99 Arctic Silver, Boxster Red interior.
99 Porsche Boxster
Old 07-24-2014, 06:59 PM   #84
Great shot of our 2003 in the sunshine state
Porsche Boy is offline   Reply With Quote
Old 07-24-2014, 07:51 PM   #85
2003 Base with 124k miles. I've owned it 10 days! This is my 3rd Porsche, 1st Boxster, and 1st Post!
r00ster is offline   Reply With Quote
Old 07-24-2014, 08:36 PM   #86
Chuck W.'s Avatar
Originally Posted by Porsche Boy View Post
Great shot of our 2003 in the sunshine state]
One of the best photos I have ever seen posted. Nice job!
Nice. And, welcome!
1995 Porsche C4 Cab
Old 07-25-2014, 12:37 AM   #87
Spinnaker's Avatar
Just hit 114 K.
Old 07-25-2014, 07:10 AM   #88
around 76,500 miles. I bought it a year ago with 58,500 on it. It's my daily driver. Oh, yeah, it's a 1999 Boxster
Old 07-25-2014, 07:25 AM   #89
BirdDog's Avatar
My 2001 Boxster S - 73K miles. Nearly suffered catastrophic engine failure from a stretched/worn
main timing chain,but was saved by the magicians at Flat-6 Innovations/Raby Engine Development.
They basically replaced almost all wear-prone parts and installed their IMS Solution. I'm currently
running it through a 2,000 mile break-in.
Old 07-25-2014, 08:23 AM   #90
2002 S, owned since almost new, 72K, lots of improvements (ROW M30, lo temp thermostat, underdrive pulley, all new brakes and stainless lines, 997 shifter etc). I do most of the work myself. Autocrossed hard on a regular basis
navair is offline   Reply With Quote
Old 07-25-2014, 08:59 AM   #91
Luckyed
Luckyed's Avatar
If you don't mind me asking.....what symptoms did you encounter prior to the timing chain issue being identified?
2001 Base 2.7 - Arctic Silver - 5 speed - Comfort Top -
3-4 Stalk OBC Upgrade - Double DIN Head Unit
Luckyed is offline   Reply With Quote
Old 07-25-2014, 03:37 PM   #92
BirdDog's Avatar
My camshaft deviations were in the 8-9 degree range. I heard chain noise but thought it was probably
that the variocam tensioner paddles were shot. It also had a slight rear main seal oil leak. I sent the car
to Raby Engine Development / Flat-6 to get the variocam chains and tensioners replaced and have
an IMS Solution installed.
During their pre-qualification inspection for the IMS Solution they found very fine black particles in the
lower sump cover and some metal in the oil filter. I had changed my oil and filter less than 100 miles
before this, so this was a HUGE red flag. The black particles turned out to be the main chain tensioners/guides
being chewed up by the main timing chain (the one that runs between the crank and IMS). They tore my engine
down, layer by layer, until they found it. They had never seen this type of failure before. Ever. But they kept
digging until they found it. That attention to detail is why I sent it there. Seriously, I can't say enough good
things about that shop!
Old 07-25-2014, 09:11 PM   #93
Originally Posted by Chuck W. View Post
Nice. And, welcome!
Thank you, it's great to be here! I've been reading these boards, thread after thread, as one would read a great book - I can't put it down!
Old 07-26-2014, 03:54 PM   #94
2010 2.9, Meteor Grey over Sand Beige, PDK, PCM, Bi-Xenons, heated & cooled seats (not at the same time), yadda, yadda, yadda...
24,300 miles
FirstPorsche987 is offline   Reply With Quote
