Old 06-25-2014, 06:55 PM   #1
More's Avatar
Bizarre Clicking Sound.
Hi There,
I just recently changed my rear wheel tires and a couple of days later I noticed a bizarre clicking noise coming from the rear of the car. It sounds like it's coming from the engine.
I have uploaded a video of the sound to youTube. If someone could please have a listen and let me know what it might be that would be great.
VIDEO LINK: Porsche Boxster - YouTube
1998 Porsche Boxster 986 Convertible.
More is offline   Reply With Quote
Old 06-25-2014, 07:31 PM   #2
I am my own mechanic....
Timco's Avatar
Sounds like a classic valve tap.
'08 VW Touareg T-3 wife's car
Old 06-25-2014, 07:35 PM   #3
Jager's Avatar
Loose spark plug? Exhaust leak?
Jäger
300K Mile Club
Old 06-25-2014, 08:10 PM   #4
More's Avatar
Cause and is it an easy fix?
Old 06-25-2014, 08:19 PM   #5
Timco's Avatar
My truck (pushrod 6) makes the exact sound. Always a perfect tap, faster with revs, perfect rhythm. Crisp sound. My issue is a stuck lifter that gets quiet with oil pressure. If valve tap likely a lifter. Oil changes and filter all on schedule?
That's under the valve cover and under the cam. Last DOHC car I had had hydraulic lifters that stuck and went bad. Also made exact same crisp tap.
Old 06-25-2014, 08:28 PM   #6
More's Avatar
I just had the oil and filter changed over a month ago. First the idiot put the wrong filter in and it was leaking like crazy so I had to take it back and he put the correct oil filter on this time and the leaking has stopped since then.
Old 06-25-2014, 08:32 PM   #7
A lifter will make a noise at half the engine speed. the video sounds like a lifter/cam follower or whatever they call it. I would check it pretty quickly.
SoCalBlackbox is offline   Reply With Quote
Old 06-25-2014, 08:36 PM   #8
Timco's Avatar
I would want to know what PN filter was used, oil weight, and if checked when filter was re-changed. If the filter used first was restrictive, well......
Jake Raby also mentions pick up screen being clogged with gasket making material is common if pan has been pulled.
Old 06-27-2014, 12:32 AM   #9
More's Avatar
No noise today. How weird. I won't get too excited because I know it will come back.
Old 06-27-2014, 04:38 AM   #10
Timco's Avatar
That's what my truck does. Taps when low on oil, very cold weather. Then it vanishes for days. Then taps loud and crisp. Always goes away before it warms to operating temp.
Old 06-27-2014, 05:42 AM   #11
Topless's Avatar
Sounds like a pulverized lifter. Needs fixing soon or it will grenade and send shiny bits everywhere internally.
Old 06-27-2014, 07:38 AM   #12
Perfectlap's Avatar
^ same failure in TheStone's recent thread for his track car.
so apparently a noisy lifter is not something you can live with it seems...
Old 06-27-2014, 05:57 PM   #13
More's Avatar
Can you remember the name of the thread?
Cheers!!
Old 06-27-2014, 07:19 PM   #14
Topless's Avatar
Cheers!!
Here you go. A little lifter disaster.
http://986forum.com/forums/general-discussions/52798-engine-failure-pics.html
Old 06-27-2014, 07:51 PM   #15
Timco's Avatar
Who was it that had the broken valve spring? That thread had good pics and was more along the lines More would follow since his has not failed to that extent yet. Of course the OHCs come off, but not the heads.
