Old 06-22-2014, 02:16 PM   #1
Gas Station Pumping problem
Hi guys,
I have been experiencing a weird gas station pumping issue since I got my car a year ago. Whenever I get gas at the Shell station right by my house, the pump would stop when the gas tank is actually full, fuel gauge showing 4/4, which is normal for everybody. However, when I get gas at a different station (Chevron, 76, etc.), the pump would stop automatically when the car is only 3/4 full, always. I haven't had a chance to test other Shell stations or all the other stations, but for now, only the Shell station(s) would fully fill my car. Has anyone experience anything similar?
Info: 2001 Boxster base, 130k miles, new gas cap, Southern California.
hancock1701 is offline   Reply With Quote
Old 06-22-2014, 02:18 PM   #2
I am my own mechanic....
Timco's Avatar
It's the fuel vapor recovery system built into the pump. The short fill tube traps too much vapor.
'08 VW Touareg T-3 wife's car
Old 06-27-2014, 09:24 PM   #3
So it's the gas station's pump, not my car?
Old 06-28-2014, 02:56 AM   #4
tomc88's Avatar
yes, it's the pump.
a common problem with all cars (all I've owned at least)
- you have to hold the pump at all sorts of weird angles until it flows.
I always check how many litres of fuel I am putting in too, because sometimes the pump cuts out and you're not sure whether to click the pump again, incase it really is full and petrol sprays out all over you
2001 Boxster S
tomc88 is offline   Reply With Quote
Old 06-28-2014, 03:06 AM   #5
i have noticed this too. thought it was my car. wasn't really paying attention to where i was when it happened. but has happened a few times now.
-Tuan
tuanle16@juno.com
tuanle16 is offline   Reply With Quote
Old 06-28-2014, 04:58 AM   #6
If you put the nozzle in the filler upside down, it usually works pretty well.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
Old 06-28-2014, 07:02 AM   #7
Timco's Avatar
I about cried. Bought my car in Orange County LA and drove back. Pumps in LA were fine. M
Got to the middle of the desert driving back and stopped at a small station for gas. COULD NOT GET THE CAR TO TAKE GAS!!!!!!!!!!! I tried everything. Got 1/2 tank in it and that took about 30 min. These people were peeking over at the guy in the nice Porsche that had been filling up for half an hour when they went in to eat. What an ordeal. I searched gas Boxster fill and found one discussion on it. Ahhh, the days of smart phones.
Old 06-28-2014, 10:43 AM   #8
Tim,
Your problem -it won't take gas except at a very slow rate is a different problem. There are two likely culprits
1.Fuse E 6
2.vent tube(s) have slipped in the filler neck and are blocking the flapper valve from opening.
Both are common problems
1. is an easy fix -I use a very slightly higher amperage ,slo-blo fuse.
2.is very tedious -see Search for details.
