Old 06-18-2014, 08:30 AM   #1
rough noise from engine
can anyone help with a diagnosis? occasionally, as i am in 3 or 4 gear...as i let off the gas, there is a loud hum or growl from the engine compartment. it typically only happens when the rpm is about 3000. it will go away if i press on the gas or clutch again. but it is annoying. it only happens when i am driving and let off the gas. it sounds similar to driving on a very rough road.
thoughts?
-Tuan
tuanle16@juno.com
tuanle16 is offline   Reply With Quote
Old 06-18-2014, 08:59 AM   #2
Nimbus117's Avatar
Have a look at this:
Boxster 986 vibration @ 3000/3200 rpm (fix?) - 986 Series (Boxster, Boxster S) - RennTech.org Forums
2003 Boxster 2.7L
2010 Civic Type R
Nimbus117 is offline   Reply With Quote
Old 06-18-2014, 06:47 PM   #3
thanks nimbus. sounds like others are having the same problem.
-Tuan
tuanle16@juno.com
Old 06-18-2014, 08:28 PM   #4
Jager's Avatar
New flywheel fixed mine about 80K miles ago.
Jäger
300K Mile Club
Old 06-19-2014, 07:23 AM   #5
Nimbus117's Avatar
Mine does it when hot, it's annoying but at least you know it's what Porsche call 'normal'.
2003 Boxster 2.7L
2010 Civic Type R
