Old 06-10-2014, 07:14 AM   #1
saintdrug's Avatar
Send a message via Skype™ to saintdrug
Few issues need help
I am visiting my mechanic this Friday, for a full service.
my boxster 2002, I ordered a new key and he programmed it all works fine.
now, when I lock it, sometimes, it makes a horn sound, indicating something is open, but everything is closed, doors, windows, ashtray, roof, and the lock button on the dash is like red. any idea why it does that? it sometimes also does it when I unlock it.
issue 2:
when you open the door the window is supposed to open a bit so u close the door and then close back so it doesn't hit the edge on the top.
sometimes it does open sometimes it doesn't, like it gets confused, (driver side) on codriver its ok, any idea what to inspect? dust etc..?
I tried holding the window button down for 20 seconds to reset, but I don't know if it worked, since I still have it. it cannot be the regulator, since sometimes it works.
Best Regards,
Chris Abou-Chabké
www.blackhatethicalhacking.com
Boxster 2.7 2002 with Bose Proud Owner
saintdrug is offline   Reply With Quote
Old 06-10-2014, 08:07 AM   #2
Multi-Boxer Driver
Deserion's Avatar
The window drop is likely the microswitch in the door handle.
For the alarm horn, sometimes it might be the center console lid. Try closing it firmly and seeing if that may make a difference.
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
Old 06-10-2014, 08:41 AM   #3
saintdrug's Avatar
thanks, so microswitch, is what I will tell the guy, he needs to open the door I guess to check this yes? replace it maybe? check it maybe some dust etc..?
Best Regards,
Chris Abou-Chabké
Old 06-11-2014, 07:41 AM   #4
Symptoms very much -- identical? -- to the ones my 02 manifested when what proved to be the passenger side door lock assembly was bad.
The tech hooked up the diagnostics computer and read the codes and did some other things to see if the problem was due to some other component as the door lock assembly is one of the most expensive items but it proved to be the door lock assembly.
Be sure the cabin floor under the seats, the passenger seat in particular, is dry and the doors do not have any dampness at the bottom areas.
Rockster is offline   Reply With Quote
Old 06-11-2014, 08:06 AM   #5
saintdrug's Avatar
thanks I will bring it to his attention this Friday when I have the service of the car.
Best Regards,
Chris Abou-Chabké
Old 06-11-2014, 08:07 AM   #6
saintdrug's Avatar
also look at Porsche answer, I found them 60 euro on ebay
340 euro each from Porsche, lol..
Good morning.The oxygen sensors are in stock.You will need 4 pieces and is 340.00euro EACH.We will give extra 10% discount on parts.For the labours you have to aplie to the service and speak with Charis.
Thank you.
Kind Regards,
Marios Skoufarides
Parts Manager
A.I. Motokinisi Ltd
15 Megaron St.
Strovolos 2032
Nicosia, Cyprus
T: 777.71.911/+357.22.353.994 (international users)
F: 777.72.911/+357.22.354.513 (international users)
Best Regards,
Chris Abou-Chabké
