Old 06-03-2014, 08:09 PM   #1
jmccjr's Avatar
oil level way low on gauge
I changed my oil for the first time today and replaced the exact amount which I took out (8 quarts) but now the oil level gauge in the dash shows one dash up from the bottom. Oil dipstick shows a little above halfway between min and max. What would cause the substantial difference in the two. Any advice would be greatly appreciated.
PS. I had no metal shaving
2001 Porsche Boxster
Orient Red
jmccjr is offline   Reply With Quote
Old 06-03-2014, 09:11 PM   #2
who knows? just make sure you add enough to get it to the top line.
Old 06-03-2014, 09:55 PM   #3
Porsche9's Avatar
Definitely go by the dipstick.
03 Carrera
89 Carrera 4
89 944 S2
78 911SC
Old 06-04-2014, 12:07 AM   #4
Steve Tinker's Avatar
The difference between each segment of the oil gauge is only about 100ml, so if your gauge is showing halfway, you under measured only slightly.
Be careful when you top up, as it will only take about a cupful or so to get it to the max level.
2001 MV Agusta F4.
Old 06-04-2014, 04:39 AM   #5
schnellman's Avatar
I always underfill by two or three marks when changing the oil, and then top up one tablespoonful at a time. That gauge is damn sensitive, and I don't want to overfill.
Old 06-04-2014, 05:07 AM   #6
Did you account for the oil in the filter - either going in or coming out?
Old 06-04-2014, 05:27 AM   #7
kk2002s's Avatar
The dip stick is your source of truth. The gauge is all over the place
If I had a later boxster with only the gauge I'b be oil level paranoid all the time. I don't know how you guys with only the gauge sleep at night
Seal Grey
Old 06-04-2014, 07:40 PM   #8
jmccjr's Avatar
Steve Tinker- Ill add a bit to see if the dash gauge goes up a little.
Bfeller- Yes I emptied filter oil into collection pan before we took the measurement of the waste oil.
Before I changed the oil I checked gauge and it was right on the full mark which I assumed was one line down from top. Then I replaced with the exact same amount that I took out that's why I'm baffled by the large variance. Sorry for the newbie paranoia.
Orient Red
