Old 03-25-2018, 10:08 PM   #1
Pdwight's Avatar
I would opt for a new one
This is one of those parts that really should be a new item. Think about it....any used switch is going to be 12 to 17 years old and already breaking down. This switch has a bearing on so many things...nothing against Woody at all....just start right with something like this.
Dwight
Old 03-26-2018, 01:54 AM   #2
Nothing wrong with buying used if the person selling it knows what they're dealing with. You can usually feel the difference in a good or bad one. New $162, used from me $50. It's also a pretty simple process to replace one. I agree that there are parts that are best bought new but the headlight switch isn't one of them. It's a mute point from me right now as I've taken a break from selling parts and I don't believe I have any good ones anyway.
Woody
Old 07-22-2018, 08:31 PM   #3
Right high beam went out and the switch cannot turn the knob to Parking lights (stuck). Also when I pull the knob to turn the high beam it goes back inside. When I shake the switch it rattles like there's a broken piece inside. Used multimeter to measure voltage on headlight assembly connectors 2 (ground) and 4 (high beam) there's no voltage reading. Is this a broken switch that cleaning will not fix?
BoxsterHtownTX is offline   Reply With Quote
Old 07-23-2018, 03:50 AM   #4
Multi-Boxer Driver
Deserion's Avatar
As it's near-identical to the switch in my Mercedes W124, the plastic breaks down inside and crumbles. I've had to replace a genuine MB switch on mine 6 years after last installing... a genuine MB switch.
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
Old 07-23-2018, 08:18 AM   #5
1997 Tip, 2018 Macan
rexcramer's Avatar
Somewhere on the forum, is a picture of an old switch that was X/O and opened up. It is just pieces flopping around on the inside. There is a lot of German engineering going on inside that switch.
Old 07-24-2018, 09:13 AM   #6
MN 986's Avatar
I had a similar headlight issue recently that was solved with a new headlight switch.
I read an old post on a different forum that a good test for a bad switch is to turn the switch to low beams on. If the lights did not come on, pull the knob out to the foglight position, then pop the knob back in with some force. If the low beams come on, the switch is bad. This confirmed my bad switch, and also helped me turn on my headlights for a couple weeks before I installed the new switch.
MN 986 is offline   Reply With Quote
Old 12-02-2018, 05:45 PM   #7
KevinH1990's Avatar
I am also trying the “clean before replacing” method. I more or less bathed the switch in CRC QD Electronic Contact Cleaner. ($4.77 at Walmart.). The switch has been working all day, so for now I am cautiously optimistic. I had originally planned to check with Woody for a used switch, but an earlier post seemed to indicate that was a bit of a long shot. By the way, the least expensive switch I could fin on line was $154.
