Old 05-17-2014, 03:15 AM   #1
Ashmyster79's Avatar
Send a message via Skype™ to Ashmyster79
Refilling and fuel cap
As some are aware I recently bought my 2002 3.2s I got it cheap so knew there would be issues. Fuel gauge is saying empty when it is not. Have filled up but still the orange light is on and pin on empty
Car garage said fuel sender unit needs replacing. I have checked the fuses all fine. However when I fill up or try too the petrol pump keeps clicking like it would if the tank is full which I know it isn't. This is tricky to judge as continuing and bypassing the clicks I could over fill although I doubt I will.
So my question is. When this happens why is that?
Also the fuel cap is pretty bad on the outside. The thread is good but think needs changing. I remember from my 350z when I took fuel cap off I would get a release of pressure which I don't get on the boxster. Is this something that should happen?
I am going to check the fuel sender connections and see if the float is stuck. Will do this before I spent £300 at the specialist to get it fixed.
Thanks for the information in advance.
Ashmyster79 is offline   Reply With Quote
Old 05-17-2014, 04:06 AM   #2
I have a 2002 S that I picked up in January of this year. To date every time I go to fill up I have not heard any release of pressure when removing the cap. It does sound like you have a bad sending unit but make sure the chassis ground for the sending unit is good.
Old 05-17-2014, 04:26 AM   #3
Thanks for the reply. So we have similar cars. So maybe I should not expect any release of pressure that's good to know.
I am going to go and look at the sender unit now see if I can spot anything obvious. Will take a pic and report back.
I am hoping it's just a loose connection. I wish.
Old 05-17-2014, 05:06 AM   #4
Looks as though it has had a 'glue repair' previously. Guess that looks like a crack which tells me I need a new fuel sender.
Now need to decide whether to do DIY or take it to the garage
Old 05-17-2014, 02:41 PM   #5
Multi-Boxer Driver
Deserion's Avatar
The glue is on there as a tamper marker to show if it's been removed prior. Mine had it on there, too.
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
Old 05-18-2014, 01:50 AM   #6
I thought something like that after I wrote it. I looked at the pics of others and they had the same. Thanks for that. I will get my hands dirty again and get right inside this time.
Old 05-17-2014, 05:23 AM   #7
I am my own mechanic....
Timco's Avatar
Bought my car in Los Angeles. When I was driving home, stopped in Mojave desert for gas. Clicked off every 2-4 seconds. Must have taken 20 min for 1/2 tank. Thought what in the hell did I get myself into.
Turned out, that pump had a very sensitive CA approved vapor recovery or sensor, and that short fill tube triggered it every time. Had the black rubber shroud that contacts the car. Since getting to UT and almost 2 years later, it hasn't done that once and I didn't change anything.
Some pumps.........
'08 VW Touareg T-3 wife's car
Old 05-17-2014, 04:29 PM   #8
Put the nozzle in on an angle and drape the hose over the side mirror .
Ian c is offline   Reply With Quote
