Old 05-01-2014, 10:05 AM   #21
Ashmyster79's Avatar
Send a message via Skype™ to Ashmyster79
Update. Garage called said problem has been fixed. Work carried out:
Diagnostics
Spark plugs
Coils
Labour
£680
For an extra £280 can have it fully serviced. Unsure at this stage. I have also been told that I need a new fuel sender unit
£288 labour
£198 parts
Does this seem steep and is it something that can be done by a non specialist?
Ashley
Ashmyster79 is offline   Reply With Quote
Old 05-01-2014, 10:08 AM   #22
Multi-Boxer Driver
Deserion's Avatar
The fuel sender can definitely be done at home. Hardest part is just getting the locking ring (plastic) off of the sending unit at the top of the tank.
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
Old 05-01-2014, 10:18 AM   #23
Thanks for the tip. Is there a video or any step by steps on this do you know. I will have a look.
I am pretty competent. However I have brain freeze with this car for some unknown reason. I think it's because you hear all the time 'Porsche = take to specialist'
I am determined to be more hands on with this car. I wanted to do an air filter replacement first to prove I could do something simple. If this is a simple process then I will attempt to do this job also.
Ashley
