Old 04-19-2014, 07:29 PM   #1
Benjamin's Avatar
Tips for reading the oil dipstick?
I have 20/20 vision and have the hardest time reading the oil dipstick. Am I the only one? Does anyone have any tips or tricks that make seeing the oil on it any easier? The electronic gauge is nice for day to day monitoring, but I prefer to periodically get a dip reading if possible. If I get the light just right and hold it at the right angle and really close to my eyes, I can kind of see it. Yes, there is enough oil in my car and it is registering on the stick. I think I may have finally found something on my Chevy that I prefer to the Porsche.
Benjamin
2000 986 S - "The Black Widow"
Benjamin is offline   Reply With Quote
Old 04-19-2014, 07:39 PM   #2
I am my own mechanic....
Timco's Avatar
I thought my eye sight was fine until I got my first pair of reading glasses. Man, what a difference!
'08 VW Touareg T-3 wife's car
Old 04-19-2014, 07:40 PM   #3
jb92563's Avatar
Having pristine virtually clear oil in your engine is a good thing but does make it hard to see.
like you discovered you have to angle it to the light just right to see it.
the only other thing I can think of, is to blow some flour on it and see where it sticks.
then you have to clean the dipstick though.
good point Timco, a magnifying glass would be good idea.
Old 04-19-2014, 10:23 PM   #4
Perfectlap's Avatar
take a blue shop towel and lay the dip stick flat on the towel.
it will leave a 'fingerprint' of the dip stick.
Then take the dip stick and place it directly below the fingerprint.
You'll see if you're at hash mark or below it.
BORN: March 2000 - FINLAND
Old 04-20-2014, 04:22 AM   #5
Benjamin's Avatar
Thanks, I'll give that a try. The oil is not only new, it was still hot from running 20 miles, so maybe I will have a little better luck with cold oil. I also had the bright idea to wrap some blue painters tape around the end and dip with that, figuring it would show up better. Thankfully I abandoned that idea because with my luck the tape would come off in the engine or tube and I'd be in a lot worse shape.
Old 04-20-2014, 04:27 AM   #6
Is there any type of white paint/coating that would live in the oil and hold up to the heat ?
rfuerst911sc is online now   Reply With Quote
Old 04-20-2014, 06:46 AM   #7
Nine8Six's Avatar
OP, I know what you mean lol
The tip of the stick is matte finish. If you just wave a light source (e.g. mobile phone backlight), that will create reflections where there is oil. It gets really obvious
The flashing trick doesn't work well under bright sunlight tho. In-garage or dark days only
Old 04-20-2014, 06:50 AM   #8
Timco's Avatar
I also remove it, dry it, dip it, check it.
(The oil dipstick....)
Old 04-20-2014, 08:02 AM   #9
Boxster 1999
:-) I almost spitted my coffee.
I do the same here and I do it twice to make sure.
Envoyé de mon Nexus 5 en utilisant Tapatalk
Boxster 99
Barteur is offline   Reply With Quote
Old 04-20-2014, 08:16 AM   #10
I use the same technique!
Old 04-20-2014, 08:56 AM   #11
husker boxster's Avatar
What is this dip stick thingy you are referring to?
1989 928 S4 5 spd - black
Old 04-20-2014, 09:28 AM   #12
kk2002s's Avatar
New oil is the hardest. After a few months, I can see on the dip stick.
The lay on paper towel method works. You just have to make sure your steady. I roll so you can see the stain in relation to the measure points
Definitely pull, clean, reinsert and then check
Seal Grey
Old 04-21-2014, 09:55 AM   #13
eicheldp's Avatar
MY 2004 and earlier were supplied with a dipstick to measure oil level.
MY 2005 and later just has the dashboard monitor for oil level.
2004 Boxster S
eicheldp is offline   Reply With Quote
Old 04-21-2014, 01:05 PM   #14
BIGJake111's Avatar
Do the new cars really not have a dip stick, cfos or anyone with a 981 I am actually curious about engine access on them if anyone would like to share, pics are welcome.
Sent from my iPod touch using Tapatalk
Old 04-21-2014, 02:34 PM   #15
Sorry, there isn't an imoticon for tongue in cheek or I would have included it in my comment.
Yes BJake, no dipstick starting with the 987. All electronic.
