Old 04-10-2014, 05:36 PM   #1
ATF fluid for tiptronic?
Has anybody ever heard of using Ford Mercon fluid in a tiptronic?
j911brick is offline   Reply With Quote
Old 04-11-2014, 07:29 AM   #2
Trey T's Avatar
Nope. Stick with OEM or Pentossin for your peace of mind. I stop messing around with modern AT when it comes to the fluid.
Oreilly's carry them for about $20/qt
Trey T is offline   Reply With Quote
Old 04-11-2014, 11:44 AM   #3
Not here, but you can order the OEM stuff from Pelican for 19.00 a quart.
2016 4Runner TEP
Muzzle of Bees is offline   Reply With Quote
Old 04-11-2014, 02:44 PM   #4
Registered Boxster abuser
healthservices's Avatar
I've used the Aisin OEM Type-IV fluid in the past at 7.99 a quart.
I'll be using the Redline ATF this time around as it is local at napa and 12.99 each.
Old 04-11-2014, 04:27 PM   #5
THanks for the replies. I have a customer that said he was told on this forum that it was OK. I warned him so if the trans blows up its on him.
Old 04-12-2014, 07:12 AM   #6
People seem to forget some very salient points:
1. The Tip is a bloody expensive trans to replace.
2. Very few shops can do a decent rebuild on them.
3. The correct fluid is not that expensive, or hard to find.
Old 04-12-2014, 12:28 PM   #7
Agreed.
Old 04-13-2014, 03:17 PM   #8
Valvoline MaxLife Synthetic claims Esso 71141 compatibility. This link shows 20k miles of use in the ZF-5HP with good results on the used fluid analysis:
E46 ZF Automatic Transmission ATF Fluid & Filter Change DIY - Page 7 - Bimmerfest - BMW Forums
2001 Lapis Blue Boxster S Tip (stock), 2001 Guards Red Boxster 5-speed (not very stock)
tightbox is offline   Reply With Quote
Old 04-13-2014, 05:10 PM   #9
Good to know. Thanks.
Old 04-14-2014, 12:37 PM   #10
Trey T's Avatar
If it's tested among the community and the result is good, then go for it. That's how I would make my decision.
